System Pictures & Description
Old 3rd May 2009, 05:35 PM   #1581
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
Your project gave me an idea. The side panels could be attached to perpendicular screens at the rear that are covered with the same material as the back wall. That way, you don't notice them.
How much did those drivers cost? Looks like an affordable project with satisfying results.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 3rd May 2009, 05:39 PM   #1582
carpenter's Avatar
Three post in a row, you're going to get the impression I like your project...
I'm in the process of reworking my open baffle line array and was going to position my side panels similar to yours. The only change I plan on is to add a ten degree angle to the sides--sweep them outwards a little bit towards the rear.
Do you have any trouble with resonance between the sides?
Old 3rd May 2009, 05:52 PM   #1583
hifidan is offline hifidan  Canada
Hi, carpenter
The drivers are as follow:
B4N for the woofer about 21.00CDN each
Mid is DMNA about 40.00CDN
Tweeter is TN-25 about 9.99 CDN
These mids are really transparent due to the fact that they are run full range in the upper frequencies.
With the wood, wire I used Transparent speaker wire all around and connectors and x-over parts, I used Solen caps and metal film resistors, the overall cost ran at around 1,300.00 CDN which I think is pretty cheap considering the amazing results
cheers
HifiDan
Old 3rd May 2009, 05:54 PM   #1584
As for as demanding more bass, using a RS sound meter i have a bass response to approx 125 hz, so i set my subs to 125hz so i have lots of bass.
cheers
HifiDan
Old 3rd May 2009, 06:11 PM   #1585
Default Center Speaker/Stand
Carpenter,
I just completed a center speaker that also acts as a TV stand using the same driver in a reflex box this time.
One thing I noticed, either the drivers or the x-over parts take a very long time to settle. It took over 2 months to break in everything.
as far as vibration on the panels, no vibration at all, the cabinet is dead to the touch
Cheers
HifiDan
Old 3rd May 2009, 06:21 PM   #1586
carpenter's Avatar
You have a sub...
Well, then that just about covers everything.
I'll have to remember to use a sub in my line-array system.
Good job, Dan!
Old 3rd May 2009, 06:22 PM   #1587
carpenter's Avatar
What a gorgeous center channel!
Old 5th May 2009, 02:43 AM   #1588
ikymagoo is offline ikymagoo  United States
Default new sound pipes
new speakers made from PVC pipe
Old 5th May 2009, 02:45 AM   #1589
Default pipe speakers
larger images here:
http://www.facebook.com/photo.php?pi...9623854&ref=nf
Old 5th May 2009, 04:22 AM   #1590
carpenter's Avatar
Ooooooh. They look so good with a tan.
Did you ever hear the one about the gang of elbows, Wye's, and San-Ts that presided over at the House... uh, I think they were looking for the speaker?
ta-dum...
So, how do they sound?
System Pictures & DescriptionHide this!Advertise here!
