System Pictures & Description
Old 12th September 2007, 09:14 PM   #1291
Steve Fay is offline Steve Fay  United States
Well I'll try again to attach the photo. I took at a much lower resolution. Hope it works! It didn't so I don't know how to I guess sorry.
Steve F
Old 12th September 2007, 10:33 PM   #1292
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
At the bottom of the reply window there is a "choose file" button. Push it and go grab it from your files.
planet10 needs your help:
Let's help Ruth and Dave
Old 12th September 2007, 10:47 PM   #1293
Cal thank you. I'll try again. I'm using Attach File botton? I don't get it? The file is 264kb?
Steve F
Old 12th September 2007, 10:56 PM   #1294
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The file needs to be <100 kb and a max of 1000x1000 pixels. Don't be tempted to use the preview button, that is screwy.
If you haven't the facility to shrink your files, mail me and i can do it for you.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th September 2007, 11:09 PM   #1295
Dave
Thanks for the help. I just emailed you.
Steve F
Old 13th September 2007, 09:42 PM   #1296
First I would to thank dave-Planet10 for reducing the file for me so I could post them! Thank You!
Steve F
Old 13th September 2007, 09:43 PM   #1297
And here is the pair.
Steve F
Old 13th September 2007, 10:56 PM   #1298
newfinish is offline newfinish  Canada
nice work !!!
are there sub on each side of the box?and which is a passif one (if there is one) the small or the big one? peerless subs?
can you tell me what xover you used for the subs?
nice finish what wood is this?
Old 14th September 2007, 01:00 AM   #1299
Hi Newfinish,
Thank you.
Yes there are drives on each side. There is a 10'' XLS Peerless subs on the bottom of each side and a 12" Peerless passives on the top on each side. Phil Bamberg weights them to give them the correct response.
For the crossover I'm using a Behringer DCX2496 which Phil also programs before he sent it to me.
The wood is Walnut. Actually some of it is out of three Walnut trees that I cut down and milled into what you see here.
Phil sells the plans and all the components right down to the nuts and bolts.
Steve F
Old 14th September 2007, 01:55 AM   #1300
oh so you are biamping?
System Pictures &amp; DescriptionHide this!Advertise here!
