#1211 |
The 24" driver uses an aluminum tube to help remove heat from the voice coil.
The system is tri-amped with original factory crossover points - 12db/octave @: 200 Hz 3000 Hz 7000 Hz Should be ready in a few weeks. What song should I listen to first? |
#1212 |
A voice coil cooler, that's nice
![]() Basement jaxx-good luck starts with a pretty low fundament of bass, but these speakers also seem capable of realisticly reproducing a good pipe organ piece....
#1213 | |
#1214 | |
That's the first thing I listened to. I could hear guns and explosions with my old system, but I could never listen to organ and feel it was realistic. Now I can. Hopefully you can too. Zarathu
Youth is wasted on the young. |
#1215 | |
#1216 |
#1217 |
So...Iceman...how can I buy Hartley's these days?
Any links? Thx.
"I'm glad I can build my own mistakes." https://picasaweb.google.com/115586837612433686520 |
#1218 |
You need to get a hold of Richard Schmetterer. Try calling or emailing him at The Audio Lab (http://www.audiolab1.com). They don’t advertise Hartleys much.
#1219 |
Folding speakers, 60 inch total height (30 inch folded), very close driver cones, Kapton cone speakers, high temperature square wire coils, strong magnets.
Power tapering and frequency response patterns of selected drivers were used to minimize comb-filter effect on higher frequencies. As the result, they: - Minimize vertical sound dispersion such that floor and ceiling reflections are minimized - Maintain a wide listening area with room filling, nearly constant sound intensity - Provide exceptional dynamic range and linear performance - Provide higher power sound pressure levels (SPL) - Reduce distortion as power is dispersed among several drivers - Enable higher power handling to be attained - Create very long nearfield for less difference of pressure levels on first and last rows of seats - Easy to handle because of folding design (fit in a car trunk when folded) despite of big height / width ratio when unfolded. The speakers were tested in a very reverberating club house environment and performed excellent if to compare to my previous line arrays and especially to stock speakers with 12 inch main drivers and horn tweeters. Differences were dramatical. I got one more proof of the saying "The Devil is in details". ![]()
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#1220 |
Heres mine. Sorry about the quality, but I had to extract it from my iPod, so it's badly compressed.
