System Pictures & Description
Old 12th November 2006, 08:12 PM   #1111
SergeDufour is offline SergeDufour  Canada
Send a message via MSN to SergeDufour
Default Proac Ultima
I just completed and test my Proac Ultima Clone.
This is actually no Proac model but a similar idea developped by Solen.
The sound is absolutly beautifull. Large, clear, defined. Each instrument in the orchestra is at its place and well separated from the rest.
The tonal spectrum is well equilibrated and the result is pure joy.
The only test I would like to do is to check the effect of the padding inside the box. For my taste it sounds OK but I wonder what technique I could use to really check that out.
Old 12th November 2006, 11:34 PM   #1112
v-bro is offline v-bro  Netherlands
v-bro's Avatar
You can try to make a sort of quick release system on the drivers. Or use shorter screws so you can swap the content quickly.
Another thing you could do is place both speakers near eachother and feed them mono, do A/B testing with different stuffing in both cabs..
Another thing, it looks like it you put the speaker on four "spikes". I would recommend three spikes, that way your cabinet can't unsettle...
By the way it looks very nice......
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 14th November 2006, 05:19 AM   #1113
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 14th November 2006, 06:13 AM   #1114
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by f.bcn
[excuse me for the pictures. It's better now.]
Thanx.
You must have put some serious work into those to prep them to get that finish
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st December 2006, 10:45 PM   #1115
Wavebourn's Avatar
...and matched subwoofer for line arrays:
Old 2nd December 2006, 04:12 AM   #1116
Default Proac
Well from the answer I got.... What I'm wondering and expecting is a scientific way to set that speakers.
I mean to actually measure the resonance and the tonal spectrum so I can tune them to be as better as can be.
Not a trial and error test where from one test to another you forget was it was really......
Old 2nd December 2006, 05:15 AM   #1117
kvholio is offline kvholio  Netherlands
kvholio's Avatar
=> http://www.libinst.com/wattlar.htm
With kind regards,
Klaas
Old 28th December 2006, 12:41 AM   #1118
smithy666 is offline smithy666  Australia
My latest edition: Ellis 1801s
I run a pair of Stochino ultra fast amps from the Elektor battery preamp with Gryphon Tabu CD. Main speakers are Dynaudio Finales - now switching between these and the 1801s
Ellis 1801s
Elektor Battery Powered preamp
Old 1st February 2007, 12:47 AM   #1119
rdr is offline rdr  United States
I finally got around to an update of my ancient system. It has always been modular so I could experiment.
Previously there were two subs, but that was taking up too much space.
Tweeters
Ionovacs XO 6000/48db Active
Mids
Accuton C44s XO 6000 & 800/48db Active
Bass
Dayton RS225-8 Active XO 800 & 60/12db Active 12db acoustic
Sub
Dual tandem 24" Hartleys Isobarik 20 cu. ft. XO 60/24db Active
All are fed by Hafler amps. The XO is a Marchand 4 way. Preamp is a modifed Dyna. The sub goes down to 20 Hz and XOed at 60 integrates well. It has had a torn cone repaired. The Ionovacs were rebuilt. These I have had since the late 60s. The rest is new.
Next is to try a passive 24 db XO for the tweeters and Aurum Cantus G2 ribbons at 3000 Hz. And some surround speakers for HT.
Old 1st February 2007, 10:30 PM   #1120
v-bro's Avatar
Whoa, those subs are huge, or is it the picture... it can't hurt to try new things, but in my opinion great sound was allready invented half a century ago so I won't doubt your subs sound great. Don't they?
Can't take distance from them eh? Just like I can't take distance from my old ESL-57's....
System Pictures & DescriptionHide this!Advertise here!
