Old 9th December 2003, 07:33 PM   #101
Send a message via AIM to eRiCdWoNg
My pride and joys- my 2 systems.
Its sorta messy but oh well you get the idea...
First is my home audio- delicate, detailed, audiophile, TV system. Van Alstine preamp, pioneer tape deck with digital noise reduction, arcam alpha 5 tuner, sony 510 minidisc, Adcom GFA2535 amp, panasonic VCR, go video DVD player. Magnepan MGIII speakers, DIY sub.
Next is my party system- PA system, DJ system. Loud, very punchy, alot of watts.
Spirit by soundcraft mixer, Ashly XR2001 crossover, Crown Macro-Tech 5000VZ amp, Cinepro 600x2 (my former home stereo amp- actually its a rebadged AB international amp), 2 Electro-Voice Sb180 18" subs, 2 EV Eliminator tops, 1 Cerwin Vega 18" sub. Not pictured, 2 Pioneer CDJ100S DJ mixers.
Old 9th December 2003, 10:26 PM   #102
Dommi is offline Dommi  Germany
Hy Nielsio
<What's the XO between the ~Eminence and the tweeter?
The XO is about 1500 Hz. But the eminence is playing without any frequency restriction.
<Does the ~Eminence have a tweeter-cone? / Do you know <anything about the frequency-respons of this driver?
No, the eminence have no tweeter-cone. If you want to see the frequency respons of the driver look at www.bastanis.de under prometheus test.
<s the tweeter open-baffle or closed?
The tweeter is closed.
<'m asking these questions because I find it an interesting config, <ut it might also be wise to put some sound-damping on the wall <ehind the speakers, in the case that mid/high-frequencies are <lso backfired.
Oh, you are right. I damped the left and right parts in the lower corners and so i reduced an over-frequency at 2 kHz in my room.
Mr. Bastani recomments little pads in the corners at 8 cm from the corner. The picture was made first of damping. For increasing the mass i used bituminous plates before damping.
<I also see an Audionet SAM amplifier, which confuses me in the <sense that it's way overpowered for your system. More suitable <options that come to mind: low powered triode, non-inverted <chipamp or buffered inverted chipamp (DIY or commercial).
Here you are also right. I hear musik since 15 jears, and i had many many speakers at home, i spended a lot of money, and my last speakers worked verry good with Audionet SAM. Than i heard the prometheus system and i quckly sold my old verry expensive speakers and buyed the prometheus system. Now i`m looking for a good Tube ampl. but its not so easy to find one which is as good or better than the SAM without spending a lot of money. I can only recomment everyone if you have the chance to test Prometheus system, do it. You will be enthused. For further questions please contact Mr. Bastani, he can give you more detailed information about his system. I know that my search for a speaker system with high dynamic without anny contorsion now has an end !
Regards Dommi
Old 9th December 2003, 11:18 PM   #103
Nielsio is offline Nielsio  Netherlands
Nielsio's Avatar
Smaller pictures if you will.
E-MU 0404 . Behringer DEQ2496 . TDA1543 NOS . JLTi tube buffered LM3875 . Supravox 215 Signature Bicone 125L vented
Old 11th December 2003, 12:01 AM   #104
Bose(o) is offline Bose(o)  Canada
I don't mind...I have broadband
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 11th December 2003, 11:17 AM   #105
Nielsio's Avatar
And I have 100Mbit internet; that's not the issue. The issue is that most people use 1024 x 768 as screen resolution (I use 1152 x 864), so the 1280 x 960 are far too large to fit and get a good overall view. I expect this can also be found in the f.a.q. .
Old 11th December 2003, 12:25 PM   #106
Nielsio's Avatar
Ok, that's more insightfull. Sounds like a solid system. I also expect it to sound quite similar to mine (see page 4 of this thread).
Since the (wideband) tweeter is closed, this is far less of an issue.
Now I'm looking for a good Tube ampl. but its not so easy to find one which is as good or better than the SAM without spending a lot of money.
I can highly recommend the same amplifier I am using: Joe Rasmussen's JLTi (commercial tube-buffered chipamp). In my experience, it sounds as good as the 47 Labs amp-gear and the price is excellent.
See
Tube with Power IC Output Stage - JLTi
http://members.ozemail.com.au/~joeras/
Old 11th December 2003, 05:29 PM   #107
frugal-phile(tm)
planet10's Avatar
1152x864 -- you must be on a Mac :^)
A large number of people will have even smaller screens 800x600 and in some cases 640x480. I run 3200x1200 and i find them inconvieniently large.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th December 2003, 05:58 PM   #108
Nielsio's Avatar
No, not a mac, just an ordinary AMD pc.
Old 11th December 2003, 06:00 PM   #109
Bricolo is offline Bricolo  France
Bricolo's Avatar
dave
And I use it on an Intel
Old 11th December 2003, 06:00 PM   #110
Variac is online now Variac  United States
diyAudio Editor
Variac's Avatar
I'm pretty sure the Bastani Tweeter is a Beyma.
I believe that the speaker was mentioned in a detailed magazine article, which would give more detail. The woofer is Eminence but what model I don't know. Eminence will make up any woofer you want, but I suspect it is at least based on an existing model.
How big is diameter is the voice coil? (based on the center cap diameter) What is the diameter and thickness of the magnet?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Page generated in 0.13543 seconds (79.38% PHP - 20.62% MySQL) with 11 queries
