Old 19th October 2006, 04:39 PM   #1081
Tony.ca is offline Tony.ca  Canada
Tony.ca's Avatar
Icelade your Icelante project is very cool man. great job.keep it up.
wish I knew french, to browse your website.
Thanx,
Tony
Old 28th October 2006, 09:51 AM   #1082
audiophile36's Avatar
Here is my DIY Fostex FE126e based full range speaker.Cabinet is 14" tall 8" wide and 10.5" deep with an internal volume of 11.65 litres finished with Beech veneer.Sensitivity is 95db and FR is 55hz-25khz.[IMG]Click the image to open in full size.[/IMG]
If it sounds good it is good!
Old 28th October 2006, 10:26 AM   #1083
maxw is offline maxw  United Kingdom
maxw's Avatar
Time for an update, this is my system:
DIY Preamp
DIY Dual mono Gainclones
Sony ST-JX661 Tuner
Technics SL-1600MKII Turntable:
Pioneer DV-383 DivX DVD Player
Arcam Alpha One CD Player with opamps replaced with OPA2132:
Old 28th October 2006, 10:13 PM   #1084
Hi !
3ways speaker with :
bommer monacor sph-170
medium fostex fe127e
tweeter monacor dt-25ti
Old 29th October 2006, 09:26 AM   #1085
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi, 3 way with a full-range mid? I like it, how do they sound? What are your crossover points?
Simon
Old 29th October 2006, 05:19 PM   #1086
200-3500Hz for moment
Old 29th October 2006, 10:53 PM   #1087
SimontY's Avatar
I bet they sound lovely.
Old 30th October 2006, 08:20 PM   #1088
Default ok here are some updates
I wasn't to satisfied with the dynamics,I felt is was to smooth and a feeling of 2D instead of 3D after the electrical mods I did in the room and the panels,as if I could find more detail and kinda made the pv14 the wart of the system.
so I changed my CJ PV14L2 preamp for a CJ PREMIER 10
a 93 model compared to a 2006.
the differrence is really there!!all the smoothness of the CJ with the dynamics I was looking for.
the mids were more fuller,bass richerand the high's divine
and as you can see I placed bass traps in the corners made of roxul 24" wide flling the whole corner,took me the whole bag(35$)
that got the bass to me tighter,more precise,the timbres also got better cause now I have a lot less cancelation in the room,and less aggrevating echo.
Old 30th October 2006, 10:44 PM   #1089
Speakerholic
Cal Weldon's Avatar
I see your amp on the floor. Is that because it takes two of you to lift it onto a shelf?
Oh, and you might want to throw an old bedsheet in front of the rock wool to prevent breathing the dust.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 30th October 2006, 10:51 PM   #1090
yeah that's only one side the other mono block is on the other side they wheigh 185lbs each,but I'm planning to lift them up with a wooden shelf of about 2" thick and spikes
Page generated in 0.12263 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
