Invisible speakers: who has achieved, or experienced this?
Old 11th March 2013, 09:23 AM   #11
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by fas42 View Post
Just to toughen up the requirements a bit, we won't count Ambiophonics and the like,
Also, no special, "doctored" recordings - has to "work" with conventional tracks ...
Frank
then nothing beats a flooder ie. an up-firing floor coupled speaker (UFFC)
and require at least, say 75%, of the treble content to come from a driver which is nominally directly facing the conventional listening postion ...
why? what's the point of such a requirement?
"high phooey and hystereo" - Yascha Heifetz
Old 11th March 2013, 09:30 AM   #12
fas42 is offline fas42  Australia
Banned
Because, in my experience, poor qualities in the treble reproduction are the primary cause for the "illusion" to fail. If you have the treble transducer facing away this can hide a multitude of sins, because the direct sound of the driver "working" is not heard.
If with your flooder (nice term, ), you stood next to it so the treble content was firing directly at your head, would it be obvious where the speaker was ...?
Frank
Old 11th March 2013, 09:38 AM   #13
AllenB is offline AllenB  Australia
It's not an uncommon goal. Even sound who's image focusses on the very space taken by the speaker itself can be made to sound as if the speaker is just a vision with no substance, and the sound is hanging there on it's own.
You can stare at the speaker and try to identify its existence, listening for some kind of sound signature and cast your mind how you will, but it actually looks as if it has nothing to do with the sound.
This doesn't happen with most ordinary speakers.
Old 11th March 2013, 09:50 AM   #14
graaf's Avatar
well, actually it's not "mine": http://www.diyaudio.com/forums/multi...ml#post1599729
it would and it shoud that's how our auditory system works - it's the psychophysics of sound
Old 11th March 2013, 09:53 AM   #15
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
G'day Frank,
Sonically invisible speakers? You bet. Easier than one might think.
EnABL'd drivers
EnABL'd enclosures
EnABL'd ports
Ground control pig tails
Put them together and the box disappears sonically in a normal room.
Alex
Old 11th March 2013, 10:15 AM   #16
graaf's Avatar
Originally Posted by Alex from Oz View Post
EnABL'd drivers
EnABL'd enclosures
EnABL'd ports
Is this for serious?
Old 11th March 2013, 10:21 AM   #17
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
I agree with these posts. Depth of a RHS heavy chirp or trill is my interpretation of what i hear in my example, be it ambio or stereo. That is to say the image is further or nearer than the tweeter, but the direction of origin is obvious.
exactly.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Last edited by mondogenerator; 11th March 2013 at 10:25 AM. Reason: apologies. Posted inside a quote by mistake
Old 11th March 2013, 10:41 AM   #18
Deadly serious.
Alex
Old 11th March 2013, 10:54 AM   #19
Banned
Cheers, Alex ...
I would suggest that people who haven't done so, go check what Pano actually described in the link I gave in the first post -- in essence he was able to walk almost completely around a front facing horn speaker, and even directly in front of it he was unable to mentally connect the soundscape he was hearing with the driver directly facing him: this is the level of "invisibility" I'm talking about ...
Frank
Old 11th March 2013, 10:57 AM   #20
CopperTop is offline CopperTop  United Kingdom
If you found your speakers turning invisible at some point, does it automatically mean that they were 'right'? I think we can dial up some pretty convincing illusions on demand if we play with home theatre surround sound, for example, but no one would claim it was a holographic reproduction of a concert hall. However, if there is no other information available, the listener could easily be forgiven for thinking that it was. You can even create a surround sound illusion from two speakers using DSP, and I think I've even done something similar accidentally when messing up the phase correction with my active crossover DSP. The effect can be a very convincing 'ambience' from two speakers, but at the cost of destroying the intentional dryness of a recording. However, without knowing how it should sound, the listener might think they've struck audio gold, only to find it an unsatisfying system ultimately. And I presume that by playing with room treatments, dipoles, open baffle speakers, side-firing woofers and all those tricks, it might be possible to create some sort of illusion without DSP, but again, would it necessarily be 'right' in the long run?
Invisible speakers: who has achieved, or experienced this?Hide this!Advertise here!
Extreme slew rates like 200V/us or 300v/us no use in general but can it be achieved? rhythmsandy Solid State 22 11th February 2013 04:16 PM
FeONIC Invisible Speakers Mapper Full Range 4 27th October 2010 03:20 PM
Invisible mode doesn't work head_spaz Forum Problems 2 24th August 2009 01:02 AM
Invisible Audio Solutions from Emo Labs angeloitacare Multi-Way 2 23rd January 2009 06:18 PM
Copyright ©1999-2017 diyAudio
