Old 7th March 2013, 02:00 PM   #1
gedlee is offline gedlee  United States
Default New study on loudspeaker placement
Hi All
Some months ago I received a chart from a friend that showed a rough analysis of toe-in with Constant Directivity (CD) loudspeakers showing how this could be used to improve the stereo imaging at a wider array of seating locations. I found this chart interesting and it motivated me to do something that I have thought about for awhile.
I have written a simulation of the sound field in front of a pair of loudspeakers that can be placed at various locations and toed-in at various angles. The software works, but is still a little rough. My intent is to post this software to my web site so that others can "play" with it. It uses the database of polar responses that are available on my web site - in other words it uses real measured data and not simulated frequency response and polar response.
Thus far the software is enlightening, but several questions have come to mind. First, what is the easiest way to post screen captures of the running software? It would take a lot of captures to highlight a "story" about how and why toe-in and CD works so well.
The software simulation is very simplistic, as all good starts have to be. There are no room reflections, for now, this is easily added later. Its also non-modal so it makes no sense to display < 200 Hz. There will only ever be a first and maybe second sidewall reflection as beyond this is just getting too complicated. The left and right ear signals are assumed to be unconnected, i.e. there is no cross-talk between the speaker signals and the ear signals. This is also why it makes no sense to consider multiple reflections as this assumption is far too limiting for any detailed analysis.
I have programed Fig. 3.5 from Blauert which describes the phantom source location as a function of the delay difference and the level difference at the two ears. The software uses this figure to map the "image" in the room for the particular speaker and its setup. The "image" is defined as a metric from zero (image completely pulled to one speaker) to one (image completely central). I have found that this map is extremely instructive.
The listener can be placed at various locations around the room and the specific frequency response at the two ears is shown on a plot at the bottom. This is also very enlightening because it shows that even though the image may be central in many cases, it is also very colored because of the speakers polar response. Getting good imaging with uncolored (neutral)sound is pretty difficult and very few of the speakers in my database can achieve it.
I would also like to map out the "coloration", but I am at a loss as to how to do that. Basically each point in the room can have four variables - Red, Green, Blue and Alpha (alpha is the transparency or intensity of the color). How does one "map" a frequency response - some 100 variables - into four variables? I had thought of using each base color (RGB) to show the level in each of three bands, i.e. a perfectly flat signal would then be white. But a highly colored sound could still be shown as white if the average within each band were the same. Then I thought about using the Standard deviation within each band to set the color, but this then ignores level differences between the bands. What about a single color to show the mean slope of the frequency response with the alpha channel to show the standard deviation - a bright color is colored and the color signifies "bright" (more HFs) or "dull" (more lows). there are lots of possibilities but none seems to be ideal.
Any ideas?
Old 7th March 2013, 02:09 PM   #2
Sounds interesting. Results will be free field only? Not sure I understand what "left and right ear signals are assumed to be unconnected" means?
Markus
Old 7th March 2013, 02:36 PM   #3
markusA is offline markusA  Sweden
Check out MJK's matchcad worksheets for ideas if you haven't allready done this.
No fancy 3D but it does have a fairly clean interface to handle room interaction and listening position.
Old 7th March 2013, 02:51 PM   #4
The right speaker feeds the right ear only and the left speaker feeds the left ear only. There is no head diffraction model. That is not impossible of course and I've actually done that before, but the calculations are extensive and would inhibit the real-time aspect of the map updates.
They are "free field" for now. I will later add a few side wall reflections but I still need to figure out how to show the effect of those on a "map".
Old 7th March 2013, 02:54 PM   #5
I have no idea where to find those. Does his program use real data or "assumed" directivities? If the directivity is assumed then I would not be too interested because I know all too well how accurate those models are (not).
Old 7th March 2013, 02:56 PM   #6
I would post screen shots if I knew how to do that simply. Any ideas? "Insert image" is pretty limiting in file size right?
Old 7th March 2013, 03:03 PM   #7
I can't give you anything about details but he does all the programming himself and he seems like a pretty openminded guy and would probably enjoy the discussion if you tracked him down.
quarter-wave.com is his site.
Old 7th March 2013, 03:07 PM   #8
How large are the screenshots in pixels? Resize them, save as JPGs and add them as an attachment to your post.
You can link those attached files in your post by clicking on the "Insert Image" button:
Markus
Old 7th March 2013, 03:22 PM   #9
Elias is offline Elias  Finland
Elias's Avatar
Without a proper head diffraction model all this is pretty useless and would produce nothing much but a bunch of "pretty pictures".
Home page
If our hearing would be accurate, we would be hearing two loudspeakers.
Old 7th March 2013, 03:52 PM   #10
Then please don't come back.
SU551-RS28F – a 2-way DEQX system loudspeaker measurement study gornir Multi-Way 49 11th February 2013 10:45 PM
Feasibility study 454Casull Multi-Way 10 22nd March 2009 12:23 AM
I want to study NoBit Digital Source 3 12th January 2008 02:35 PM
Loudspeaker placement djdan Multi-Way 2 25th January 2003 04:03 PM
Copyright ©1999-2013 diyAudio
