#151 |
Earl,
When moving the listener around and looking at the frequency response window there's no case where frequency response for the opposite speaker would be higher than the closer speaker unless the listening position is very far away ![]() P.S. Error when selecting "Piston"
Markus Last edited by markus76; 22nd March 2013 at 01:58 PM. |
#152 |
Markus
Thats not true at mid-high frequencies for an Abbey12c(a) at 48 degrees and about 1 meter off the wall. There is a reversal of the amplitude function over a fairly broad range. It is true that almost no other speaker does this, I agree. What is "very far away"? My setup is about 4-5 meters from the speaker plane. Is this "very far away"? |
#153 |
Thats good to know because the two programs have very common classes and one failing while the other doesn't is odd. I'll have to look for differences between the two program codes - there aren't many.
#154 | |
Could you show a larger dB range in the frequency window? Some curves don't display within the availble ±9dB.
Markus |
#155 |
Why smaller than 50 degree opening angle? It works for me at anything above about 40 degrees.
Yes, I can change the range, but I have found that the "dipole" button, which normalizes the curves at a different frequency, usually works. |
#156 |
Pretty please?
Markus |
#157 |
#158 |
Hi, thanks for all your great input to the forum.
I thought I had the prerequisites so I just clicked 'launch' here: Room Response and got this error: CASRXT6F.txt So instead I clicked on 'run' and got this error: install error log.txt I'm just a regular North American Win7 user but I am in Canada so ... ? Let us know if you want to do specific testing. Cheers, Jeff |
#159 |
#160 |
Those are the errors that I always see and I have no idea what the problem is. It reads like your computer just won't download the files. My guess is that it is the security level of your computer. It is trying to protect you from my bad software!!
| SU551-RS28F – a 2-way DEQX system loudspeaker measurement study | gornir | Multi-Way | 49 | 11th February 2013 10:45 PM |
| Feasibility study | 454Casull | Multi-Way | 10 | 22nd March 2009 12:23 AM |
| I want to study | NoBit | Digital Source | 3 | 12th January 2008 02:35 PM |
| Loudspeaker placement | djdan | Multi-Way | 2 | 25th January 2003 04:03 PM |
