diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Measuring and voicing waveguides v.s. flush mount tweeters (http://www.diyaudio.com/forums/multi-way/231472-measuring-voicing-waveguides-v-s-flush-mount-tweeters.html)
dsrviola 6th March 2013 08:19 AM
I'm about to begin my first measurements/crossover design of a system with a waveguide. I was wondering if people who've worked with waveguide designs do anything different when taking measurements and designing the crossover. Here's the measurements of the tweeter on a flat baffle and in the waveguide: http://techtalk.parts-express.com/sh...09#post1841309 As you can see there's quite a bit of "droop" in the response off axis response for the WG compared to the flat baffle. I'm thinking if I approach this like a standard design the end result is going to sound dull/rolled off because of this. If I'm used to using on axis driver measurements for crossover design, should I use off axis measurements (let's say 30-40 degrees) for a project like this and plan on pointing the speakers more or less straight ahead? (I usually measure and listen about 5-10 degrees off axis to my non-waveguide designs.)
dumptruck 6th March 2013 04:07 PM
It depends on the waveguide, and your techtalk link is broken, but the answer to using 30-40 off-axis measurements is almost definitely no. If the -6dB pattern is close to constant directivity, you'll probably want a gently falling (3-6dB) response on-axis, and if the pattern is narrowing at HF maybe a more flat response on-axis.
dsrviola 6th March 2013 05:49 PM
link repaired.
dumptruck 6th March 2013 07:59 PM
1 Attachment(s)
Looks like you could treat it as an approximation of an 80 constant directivity waveguide to me. I'd design on-axis, incorporating compensation to flatten the on-axis response in your measurement to something like this below, and crossing over to where the midwoofer has an approx. 80 pattern, i.e. -6dB at +/-40.
boris81 6th March 2013 08:18 PM
The best way to do it is to find a woofer at the particular size where it's directivity (due to beaming) matches that of the waveguide in the proposed crossover region. You can study this design for reference:
The Seas ER18DXT ported two way
There is considerable variation for woofers' directivity but if I was to give a very general reference (for a 60degree directivity) a 10" driver should cross well to a waveguide around 1kHz, 8" @ 1.5kHz, 6.5" @ 2kHz, 5.5" @ 3kHz, 4" @ 4kHz.
dsrviola 7th March 2013 06:03 AM
It's being mated to a 4" midrange: ACCUTON C79-6
AllenB 7th March 2013 01:36 PM
To keep matters flowing, once you decide whether the drivers can be matched, and where (possibly 3k5), then you might go ahead and design a crossover in the usual way. The downward droop with the tweeter response isn't a bad thing regarding why it happens, but you should still straighten it up or maybe leave some of the downward trend if it sounds better.
dumptruck 7th March 2013 02:04 PM
Yeah I'd guess 3.5kHz too.
tuxedocivic 7th March 2013 03:32 PM
Why use such a small mid Dave? I'd maybe use an 6 or 7" mid. Would look better to.
PS. I'm ryanbouma from TT.
vacuphile 7th March 2013 03:55 PM
Small mids rule in my opinion, but in combination with a waveguide they might not be the perfect solution.
Copyright 1999-2017 diyAudio
