Inherent Design Question: Inherent sonic characteristics that cant be measured?
Old 5th March 2013, 09:16 AM   #11
davidsrsb is offline davidsrsb  Malaysia
I am puzzled at reviews that praise HEIGHT in the stereo image. There is no way two ideal speakers can give height clues that are not there in the original recording (floor and ceiling echoes maybe)
Old 5th March 2013, 03:28 PM   #12
454Casull is offline 454Casull  Canada
Originally Posted by Jay1111 View Post
I dont really think the question should be is there something missing from the measurements. What needs to be resolved is, what order(s) of distortion, at what relative level(s), and at which frequency(s) is/are pleasing/displeasing.
Only a few of the things which make a speaker sound pleasing and/or accurate.
Old 5th March 2013, 05:17 PM   #13
counter culture is offline counter culture  United States
Originally Posted by Joel Wesseling View Post
Is there sonic characteristics generated from a driver that cant be quantified with todays best equipment and software?
What would constitute proof one way or the other? What evidence would convince you that there are unmeasurable characteristics, or that vice versa, all characteristics are measurable?
I see you say you knew the answer already.
1. What was it that convinced you?
2. Why bother asking?
Old 5th March 2013, 05:28 PM   #14
RayCtech is offline RayCtech
No - measurements cannot tell or quantify the sonic performance.
Old 6th March 2013, 01:29 AM   #15
Joel Wesseling is offline Joel Wesseling  Canada
My answer is NO.. Todays measurements dont tell the whole story of the sonic characteristics...Some Audible Vibration patterns are to complex to measure in its entirety with todays software and equipment..Those patterns impart a great deal on the sonic characteristics
Well, it all started with an engineer who is very knowlegeable in this area of design and measurement.. He states its all numbers and a great design is simply improving the numbers..
Okay as I go over it, He does state The difference between a good design and and a great design is Diffraction and Compression and that its hard to measure but its the only thing standing in the way between a good and great sounding speaker..
So Enlighten me with your thoughts and expertise..
Lets imagine Diffraction and compression are perfect in 2 speakers each with different driver. Do we still have a considerable sonic difference between the two? will we all hear them as 2 very different sounding speakers?
Just trying to learn
Old 6th March 2013, 02:57 AM   #16
jcx is offline jcx  United States
Default sonics = sound, physics - perception is another field entirely
if you know how all surfaces move its only a question of computer horsepower to get the sound field in a defined/known environment
several laser tools are availble today
Tools of the trade - laser measurements | Bowers & Wilkins | B&W speakers
microphone arrays, mechanical scanning could be correlated with radiation surface measurements, room multipath/modes/box diffraction...
again the physics isn't hard by PhD/top National Lab standards - the engineering, equipment cost and analysis time are expensive - really only a question of how far can you afford to go
I'm suprised that no one has tossed in an appeal Chaos yet - possible in driven mechancial resonace? - maybe - but sucessful speakers are fairly heavily damped
and proving Chaos in a physical system isn't trivial - it isn't the same as isufficently detailed modeling Chaos (Stanford Encyclopedia of Philosophy)
Old 6th March 2013, 07:40 AM   #17
If it was so simple to design the perfect driver..
In my early stages of development I used laser and the other tools.
Without I would not have been able to "see" and rectify the flaws.
When this phase was finished and surround, cone, dust cap and voice coil was performing as wanted I had still not "listened" to the driver.
I now had 10 slightly different surround / cone assemblies that passed the above mentioned tests - 100 pcs of each variant for production variation control. 4 different voice coils. 4 different magnet systems (ferrite, alnico, two different neodym)...
It was at this stage when I tested out the 160 combinations I understood that traditional measurement methods do not tell anything about the sonics.
Later when I tested AMT prototypes I was able to verify that I could deform the diaphragm (with a heat gun) to the point where it was completely defect and no output at all.
It was very easy to listen and hear the drivers sound worse and worse - at some point there was more noise / distortion than sound.
However the measurements of harmonic distortion told that the driver was performing very good even at this point.....
Old 6th March 2013, 08:07 AM   #18
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Personally I don't think it's a case of not being measurable, but more one of not knowing how to interpret or correlate the measurements to the subjective impressions.
Our brain is a supercomputer, and is programmed to pick up differences in sounds for many reasons. Even with enough computing power, we would still need to understand what it is that our brains are doing to be able to have a chance of developing visualisations of measurements that we could reliably point to and say this is a predictor of say phantom image quality.
Where it gets really messy is when we take into account the tricks that our brain can play too. Then it gets really murky.
I've mentioned before that I think it would be great to do controlled experiments with both sighted and blind listening where the subjects brain waves were monitored. I think this could be helpfull in improving the understanding between measurements and listener impressions. Of course interpreting differences in brain waves and what that means is another can of worms as well
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 6th March 2013, 09:19 AM   #19
gainphile is offline gainphile  Australia
gainphile's Avatar
Can we measure PRAT ?
Let's say "My speaker's PRAT score is 90" hence it's superior to your speaker's PRAT 75.
http://gainphile.blogspot.com
Old 6th March 2013, 10:43 AM   #20
what's with the "standard measurements" strawman - I thought the thread title didn't preclude any tech, level of effort, expertise
and again the conflation of "sonics" with human perception - I claim sonics should be the science of sound waves == physics
it should too obvious to anyone here that there's no complete understanding of percption, interpretation of sound fields by diverse ears and brains - not worthy of yet another thread that can't possibly go anywhere
Inherent Design Question: Inherent sonic characteristics that cant be measured?Hide this!Advertise here!
Listening seat against rear-wall - How bad is it? How to reduce inherent problems? keyser Multi-Way 30 11th September 2015 01:57 PM
Class A - Inherent disadvantages ? Borat Solid State 91 11th September 2009 07:00 PM
Any inherent problems with this enclosure design? Lothar34 Subwoofers 21 4th October 2006 10:32 PM
Tube amp design characteristics? NewVintageNut Tubes / Valves 20 30th May 2004 09:07 PM
Sonic characteristics of Leach amp? sobazz Solid State 8 23rd October 2003 12:10 PM
