Looking for a 12" woofer
Old 4th March 2013, 06:27 PM   #1
pguerin is offline pguerin  France
Default Looking for a 12" woofer
Bonjour,
I'm lookink for a 12" woofer in order to make a passive system with
a Davis 16GKLV6M and a Audax TW034.
The primary idea is to cross at 350 Hz first order as was done in a kit called MV15, see pdf in attachment.
I think the speaker must match few criteria :
- sensitivity around 96 db for 3/4 db BSC (16GKLV6M is around autour de 92 crossed by a self of 0.6 mH)
- max enclosure size around 90/100l
- price 200 € max
I've seen two beyma references wich seem interresting :
12LX60V2 : ~200 €
SM112 : ~120 €
Has anyone used this speakers ?
Any advices welcome
Old 4th March 2013, 06:37 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
new 12" Mivoc looks interesting, and can be weight tuned for closed box
or maybe look at SB Acoustics
but most 12" Pro/PA woofers seem to have very high Fs
if its to change an already existing speaker, I suppose you know how to change the crosover for the new woofer ?
Old 4th March 2013, 07:48 PM   #3
Thanks for the answer trinitus[.
I'm looking for the refs.
Original woofer had a fs of 38 Hz, Beyma SM112 has also a FS of 38 hz.
T/S parameters below of the 31TCA12 :
PN: 150W - QTS: 0.31 - FS: 38 - VAS: 216 - BL: 12.6 Re DC: 6.9
sensitivity 96 db/2.83V
I hope so
Old 4th March 2013, 08:43 PM   #4
you have to check each woofer with a calculation or simulating software
or else you wont know how it works
btw, is it a speaker you have, or part of it ?
or is it just 'an idea' for a 'design' ?
Old 4th March 2013, 09:05 PM   #5
tvrgeek is offline tvrgeek  United States
I still like the 80300 Peerless, but 350 may be a bit high.
Old 4th March 2013, 10:10 PM   #6
ScottG is offline ScottG  United States
Originally Posted by Pascal GUERIN View Post
..I've seen two beyma references wich seem interresting :
12LX60V2 : ~200
SM112 : ~120
Any advices welcome
http://profesional.beyma.com/ingles/pdf/12LW30N.pdf
-looks like it can be found for around 150 euros from several sources..
It has a more linear response and lower non-linear distortion at lower freq.s..
perspective is everything
Old 4th March 2013, 10:18 PM   #7
regarding Beyma, how about Beyma's Car audio 12" Competion ?
Old 5th March 2013, 06:50 PM   #8
Yes, I own the medium 16GKLV6M (second hand) and the TW034.
Concerning the simulation, i'm able tu use WinISD but i'm looking for advices from "end users"
Old 5th March 2013, 07:15 PM   #9
murphythecat8 is offline murphythecat8  Canada
Beyma Speakers - Beyma 12BR70 speaker - Beyma 12BR70 250 watt 12" woofer for all hi-fi and studio monitor bass speakers. Beyma 12BR70 and other Beyma 12" speakers here.
Old 8th March 2013, 08:01 AM   #10
Thank all for the answers,
ScottG, the 12LW30 seems to be an interessting driver
Another candidate could be the one of the AE TD12 serie, I've asked AE for the shipping costs.
I'm going to do simulation with WinISD for all the drivers expet the 12BR70 who needs a ~90l enclosure.
I also own a sub 60l enclosure that could be used for tests.
Looking for a 12" wooferHide this!Advertise here!
12" woofer with ff85k wicked1 Full Range 78 3rd December 2013 04:26 PM
FAST build with an Alpair 7.3 and a 12" Peavy Pro 12 woofer golgiapparatus Full Range 6 2nd November 2012 12:07 PM
Wanted: Volt 12" and 15" woofer gengis Swap Meet 0 12th April 2005 12:29 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
