Aino gradient - a collaborative speaker project
Old 28th July 2013, 06:34 PM   #231
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
I got the boxes back from the painter, but the colour went too blueish because of pearl-fillers used with lacquer. However we decided to keep them as such, and the painter didn't charge much for the work because of the colour mismatch.
One speaker is now wired finally, except for the protective cap for the tweeter. I fiddled with bass peq and xo in the room (final listening position) After these measurements I changed LM high-pass,eq between 200-500Hz and level for even better results. Outdoor and indoor sessions will follow this, but I think that I'm close...
Room mode bumps at 60, 120, 240Hz
Single speaker 1,5m response at 60ms and room response at 200ms (each line average of 6 measurements at 1m sphere)
File Type: png ainogice 81 room r 0¤ all indiv 60ms 13.png (74.7 KB, 344 views)
File Type: png ainogice v7 room l r lr aver 200ms 16.png (54.6 KB, 331 views)
AINOgradient speaker project
Old 1st August 2013, 01:12 PM   #232
Juhazi's Avatar
I have exhaged some PMs with Greebster -thank you Mike! We are figuring out/trying to understand and improve dipole behavior of the mids. I chose the mtm arrangement after chosing to use 3" high-mids because of their smaller diameter. This creates some other problems - vertical lobing, interferences from the tweeter's body and the baffle/frame all these are mounted on. Frame is 8mm thick. The lower mid suffers from the nearness of high-mids, top of bass box and the post behind it. Post's cross section is elliptic to minimize diffractions.
Poor quality photos of ready-made AINOgradients attached!
I also attach graphs that may help to analyze the behaviour of my mids. All measured outdoors, version AINOgradient Ice v61. All elements attached all the time, just different electrical connections and rotation.
From these graphs we can also see what parametric eq and xrossover setting do. Dipole corrections loses a lot from efficiency! I use minimal boost and only in the region of highpass xo, to avoid digital clipping in minidsp.
My selection of amplifiers is working well. B&O Icepower 125ASX2 are drivin W and LM, 50ASX2 are driving HM and T. I use a Yamaha RXV-630 AV-receiver as preampifier and "mixer". SPL with AINOs is a bit louder than a pair of MarkK ER18DXTs at same volume setting. I don't have a meter but max spl is far above 100dB (my ears started hurting at -10dB) and there was no clipping, distortion or resonaces. LM membrane was moving some 4mm. I use LT type eq in minidsp for SEAS L26ROY woofers, something like -7dB between 30 and 70Hz.
Sorry, I don't want to say anything new about the sound, because I want to get more opinions.
W SEAS L26ROY in sealed 25 liter, polyfill (monopole)
LM Beyma 12MWNd nude, tilted (dipole)
HM Vifa NE95-4 nude, pair in series (dipole)
T Fountek NeoCD3.5H (monopole)
minidsp 4x10HD, acoustic xo's 150HZ LR4 800Hz LR2 3100Hz LR4
Bang&Olufsen Icepower 125ASX2+50ASX2 modules (total 4 channels/speaker)
File Type: png ne95 pair vs single 0 90¤ 3ms nosmo text.png (102.9 KB, 317 views)
File Type: png beyma 12 0¤ raw vs eq xo 90¤ 12ms nosmo.png (92.1 KB, 50 views)
Old 1st August 2013, 01:36 PM   #233
Juhazi's Avatar
Here is HM pair in same scale as LM in the post above, for easier comparison.
Old 2nd August 2013, 06:24 PM   #234
Juhazi's Avatar
More evaluation of MTM vs. MT arrangement
I played a little more with my old measurements, v61 outdoors. Here I use 6ms IR window. Pair of M is always darker line, single(lower) M is pale color.
There are differencies, but no consistency to my eyes.
However I can hear lobing effects with MTM when playing sine waves. More listening test will be done with pink noise, sine and music when I have an opportunity. SPL, distortion etc. -wise a serial pair and single are equivalent. A benefit from MTM is symmetric vertical directivity and perhaps some more "attack" in transients.
Old 2nd August 2013, 07:37 PM   #235
Greebster is offline Greebster  United States
Greebster's Avatar
A benefit of MTM setup is wide horizontal directivity and narrow vertical directivity. This way we can reduce floor and ceiling reflections.
Old 3rd August 2013, 08:16 AM   #236
Juhazi's Avatar
After sleeping over previous post I noticed that I was mixing indoor and outdoor measurements. A new outdoor measuring session will come some day... and critical listening with friends. I don't want to cut off the upper 3" mid unless I am confident that it is better than mtm.
The problem with lobing and many other intermodulation effects is that they are difficult to catch with measurements. Even more difficult is to identify them (what is causing each) to be able to do something about them.
A dipole multiway speaker never behaves perfectly dipolic. Interferences can't be avoided, only compromized and minimized.
Old 8th August 2013, 07:39 PM   #237
Juhazi's Avatar
The weather doesn't permit outdoor measurements, so indoor... I made some changes to xo, its now all LR4 acoustic, xos 200,1000,3300. Horizontal response is the same as before, nothing new.
Front wall distance affects response a lot. Pseudoanechoid 6ms vs 60 and 100 cm to front wall 200ms - first attachment.
I measured vertical directivity of mtm and mt arrangement. Now I got some sensible results and I must say that mt has perhaps better vertical directivity. However mtm is reasonably even till +/- 10¤ which means +/- 50cm at my listening distance. I'll stick with mtm. I also mesurend +10¤ at 30¤ horizontal and it is just like 0¤, not shown here.
Room response average of 5 mic positions, R speaker at 60cm to wall and bass too heavy. Just to show how much this means.
Horizontal directivity, this time short IR only 4ms. This is mtm. Please notice that 2-3kHz is a bit hot here, but same range is cool at vertical offset - compensates total power response..
Old 9th August 2013, 07:33 AM   #238
lolo is offline lolo  France
lolo's Avatar
Yep. Also the drivers will have different path lengths hence different cancellations freq that will flatten each other out.
Old 9th August 2013, 07:39 AM   #239
lolo's Avatar
Hello!
60cm? You won't be able to get good midrange response that close IMO. It shows on the graphs, response flattens only around 1k. In my experience, dipoles are a b.... to place, where the midrange is great, bass is crap. Theoretically best place for bass is near side walls/corners. Further away one might manage to excite only one or two modes and use EQ. Or sit very, very close to the speakers..
Old 9th August 2013, 09:58 AM   #240
zmyrna is offline zmyrna  United Kingdom
Juha,
Why don't you ditch your dual cone mids and get yourself a pair of B&G Neo8S?
Then you would have the same set of drivers as myself (my Founteks are on the post).
Well, almost same: my 12" PA is Faital 12PR300.
You can do a quick OB vs sealed cabinet experiment and go from there.
I really like the driver placement on Greg's new studio monitor.
Aino gradient - a collaborative speaker projectHide this!Advertise here!
