Aino gradient - a collaborative speaker project - Page 22 - diyAudio
Old 25th June 2013, 12:13 PM   #211
Juhazi is online now Juhazi  Finland
Juhazi's Avatar
Looking for comb filtering - closeups with no smoothing
MTM red
MT blue
Measured at tweeter height 100cm to floor, 150cm distance
Low (only highmid playing) measured ~90cm to floor, at lower mid's height, 150cm distance
--> I can't find a flaw in MTM setup
AINOgradient speaker project
Old 25th June 2013, 03:52 PM   #212
Juhazi's Avatar
Here is a thread about lobing and comb filtering. It happens in every multidriver system with any amount of overlapping frequencies at xo. Theoretically also in a single transducer's membrane from edge to edge. The critical limit is generally 1/4 of wave length:
Center to center distance/ unified wavefront limit/ first major comb freq range
8"/ 1800 Hz/ 3200 Hz
6"/ 2300 Hz/ 4100 Hz
4"/ 3600 Hz/ 7000 Hz
We must remember that cf lobing happens same plane as the drivers are. Lobing "density" gets greater with distance and smaller with frequency. One can hear it easily when playing a sine wave and moving around in the room. Surface reflections cause comb filtering too but in a more compex way. We can see the effects of this in measurement as "nulls" in amplitude response graphs. When lookin at these we must remember that they are spesific to certain distance and angulation to the source. Also when measuring the time window used makes them look different.
Basics of waves and interferencies is expaned with animations here by Dr. Dan Russell
and here is a interference simulator http://serc.carleton.edu/NAGTWorksho...ies/40826.html
This is perhaps the best animation of a two-source interference http://www.acoustics.salford.ac.uk/f...ves/super2.htm
Old 25th June 2013, 04:06 PM   #213
MTM red
MT blue
That's because you are not looking in the right place!
MTM response "flaws" are found "off axis" in the plane formed by a line connecting the centers of the two woofers (e.g. vertical plane). Take some vertical plane off axis measurements out to 30 degrees to discover the "problem areas".
You can predict what you will see using TheEdge, for closed or open baffles. It's very useful for this purpose.
-Charlie
Old 25th June 2013, 04:17 PM   #214
Using the numbers that you quoted for the unified wavefront limit...
...it is easy to see how to design a multi-way system that does not have lobing problems. If you cross over from midrange/woofer to the tweeter at a relatively low frequency and locate the driver centers as close together as possible you can easily meet the criteria for a "unified wavefront".
For instance, using a 5.25 (17cm) midbass and a 1" dome tweeter with a 4" (10cm) flange, the center-to-center distance is 0.5*(17+10)=13.5cm (about 5.25"). You can cross a modern, robust tweeter as low as 1.5kHz. According to your info, a driver that is 6" apart will have a unified wavefront up to 2300Hz, so there is about an octave between the crossover point and where the wavefront starts to develop lobing. This allows the midwoofer response to be sufficiently attenuated and lobing is not a problem. It's all good!
-Charlie
Old 25th June 2013, 05:05 PM   #215
Juhazi's Avatar
There is a way to "win" vertical lobing - CBT arrangement by Don Keele! Don Keele's CBT (Constant Beamwidth Transducer) Page When we look at Don's pdf, on page of AudioArtistry, we can see that his cbt compromises on horizontal directivity! I wonder if we could combine exceptional horizontal and vertical directivity and minimal lobing effects?!
We have a definition called "listening window" whre artifacts caused by poor lateral dispersion, comb filtering, edge diffractions etc. are minimal. I chose to have a wide lateral and narrow vertical window.
For AINO I decided to create maximal vertical directivity and uniform/controlled/constant horizontal directivity. I chose a tweeter for that (Fountek NeoCD3.5H) and a MTM configuration with small diameter mids. By cutting the edges of the tweeter I reached M to M center distance of 190mm (7½") The tweeter has loads of distortion from 2500Hz down and it is on the limit here... Also the M-M system is on the limit considering comb filtering. The xo is LR4 at 3000Hz - a compromise with these chosen ones.
As I stated in another thread, this is like cuisine - mixing materials, processing them with skill and flavouring with finesse! Another cook would have chosen different raw materials and recipes! My result is the best I can make with these!
Vertical directivity measurements from a wider angle needs a different measuring setup and a helping pair of hands! Perhaps one day... My angle at the last indoor measurement was -3,5¤. There I can see some comb filtering at 4kHz and higher. The lobes of a single mid are caused by dipole problems above the dipole null!
Old 25th June 2013, 07:12 PM   #216
Juhazi's Avatar
Charlie et al. - I have shown vertical measurements of AINO earlier Aino gradient - a collaborative speaker project
I had saved those measurements and I will postprocess them to look for comb filtering problems (which really exist, no doubt.) But just at first look there are more prominent issues, as can be expected, based on dipole behaviour and 30¤ degree angulation of lower mid. It was one guideline in the design to minimize floor reflections - angulate LM back to make advantage of dipole function and use high-MTM with a highly directive tweeter.
For a reference here is my and Keele's B&W 801 vertical dispersion, taken from Audio Artistry
Old 25th June 2013, 07:48 PM   #217
Juhazi's Avatar
Closeups of vertical dispersion of AINOgradient
Measurements were taken outdoors on lawn (grass), distance 150cm. Microphone handheld for off-axis (degrees are estimates). The v3 had a phase/delay match problem that appears as lobing just above 2kHz. Other than that we can see MTM comb filtering and dipole-typical nulls.
When listening to the speaker indoors I have distance of 2 - 3m (6-9') - floor reflections come from roughly -30 to -45¤ dispersion angle. We can see that these responses are far from even and the effect of vertical comb filtering form the vertical MTM must be a minor problem.
Old 2nd July 2013, 05:35 PM   #218
Juhazi's Avatar
I just read the Stereophile review of 107.000$/pair YGA Sonja speakers. The editor said that these are the best he has heard in his 37 years of career. Sonjas have a MTM arrangement and rather similar horizontal and vertical measured responses as my AINOgradient. I guess that the vertical lobing of a MTM is not necessarily a bad thing, considering the benefits it gives.
Old 13th July 2013, 05:29 PM   #219
Juhazi's Avatar
The 51st AES Conference is in Helsinki in August. Finnish members get free access on Wednesday, which is also netcasted Active Loudspeaker Design Masterclass LIVE WEBCAST... Registration, Helsinki - Eventbrite The topic suits me well - designing active speakers!
I will go to Helsinki for this and I willl try to find a way be there also on Thursday to hear and see S Linkwitz.
Program Program AES 51st Conference, Helsinki, Finland, August 21-24, 2013.
Old 14th July 2013, 08:08 PM   #220
Juhazi's Avatar
On a rainy day I made some minor mods to crossover and measured a speaker indoors (more than 2m from walls). The painter still has my bass boxes, But now I just wait because I have my summer holidays and we visiting our summer cabin and have all kinds of other activities often.
The bass needs a lot of taming to integrate to the lower mid and when I change the speaker's position in the room, response changes. This is mostly a learning phase for me, before I get the final boxes.
File Type: png ainogice v62 mor 0 30 60 90¤ 20ms 13.png (50.6 KB, 30 views)
Copyright ©1999-2017 diyAudio
