Aino gradient - a collaborative speaker project
Old 5th April 2013, 06:26 AM   #121
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
The xo curves above is what I'd like to have acoustically. Minidsp gives me many ways to get there. I try to follow John Reekie...
The 4x10HD minidsp will arive today finally! The Finnish Customs and FedEx have been holding it for two weeks now!
AINOgradient speaker project
Old 7th April 2013, 08:23 PM   #122
Juhazi's Avatar
I have been working hard with the proto and minidsp!
I used a 2ch amp, which measn I had to do huge number of measurements to match levels after every change in PEQ. Fortunately it is very easy to do, because when the 4x10HD is connected to the computer with usb it reads software settings "online"
The beginning was difficult but finally I started using negative values for correction too. Each channel's master volume varies from -13 to -18db and maximum corrections are around 9dB. The Tweeter had to be shelved almost 20dB above 10kHz!
Here are my graphs! 20ms used for every measurement, mic at tweeter level, distance 80cm. UMIK-1 with a calibration file. The spl level is not calibrated. The room was my home theater "bunker", it makes wiggles up to 400Hz and some early reflections. The poor directivity at 2000Hz puzzles me, it should be right on dipole area...
W to LM xo 180Hz LR 12dB
LM to HM xo 800Hz BW18dB
HM to T xo 3500Hz BW18dB
The area around 400 to 800 is very difficult.
File Type: png aino proto individual w lm hm t xo ver1.png (52.1 KB, 473 views)
Old 7th April 2013, 08:46 PM   #123
Juhazi's Avatar
This is how it looks on minidsp plugin
Old 8th April 2013, 08:15 PM   #124
Juhazi's Avatar
The xo ver2 has:
W to LM LR12dB @ 160Hz (LM inverted polarity) I also put a temporary 12dB HP filter for low bass because of huge boundary gain in my small room!
LM to HM LR12dB @ 800Hz
HM to T BW30dB @ 3500Hz
PEQ was modified too
This resulted in more even spl and directivity
I moved the proto to a little better position and used 1m distance. I had to stop making sweeps and ver2 is not finished yet, I hope to to get some graphs tomorrow with an AV amplifier.
Old 9th April 2013, 08:04 AM   #125
jlaakso is offline jlaakso  Finland
Nice progress Juhazi.
What are your feelings about UMIK-1? I've been planning on for simple mic for some time and UMIK-1 seems simple enough
Old 9th April 2013, 10:42 AM   #126
Juhazi's Avatar
Thanks, jlaakso!
The miniDSP UMIK-1 is as simple and easy as it can be! No hazzle with mic preamps etc. humming devices. Just plug and measure! The downloadable calibration file for REW is nice too. The mechanical quality is good.
I've decided to use 30 and 45¤ measurements as main guideline, as suggested by Jon Marsh and John Kreskowsky. Also it seems like my NeoCD3.5 gives way too much directivity. Hopefully it has a detachable waveguide! I must make that modification tonight!
I bought a second hand Cambridge Audio Azur 540 AV receiver for 250€ from here
Old 9th April 2013, 12:46 PM   #127
Do You plan to use that as power amp in your setup? Connect miniDSP 4x10 to 6.1 direct input etc?
Old 9th April 2013, 08:47 PM   #128
Juhazi's Avatar
CA 540 is just for prototyping, the final AINO GRADIENT will have B&O icepower modules - fully active! It might be a problem to use via AV receiver - does the pre out follow main level control?
The AINOproto v3 is finished!
Drivers:
W SEAS L26ROY closed box
LM Beyma 12MWNd no baffle tilted 30¤ backwards on the box
HM Vifa NE95 pair 120mm baffle dipole (MTM)
T Fountek NeoCD3.5H (without waveguide)
miniDSP 4x10HD settings
PEQ to control dipole effect and other variations in measured spl without xo.
xo 200/LR12dB 850/LR12dB 4000/LR24dB, levels matched
This is fun and difficult! I am happy for what I have achieved with minidsp in 4 days (the few free hours of those...) The sound is wonderful (one speaker playing) - tight and solid bass, exellent human voices and solo instruments. Very clear and fast transients and highest treble. The rooms don't seem to colorate or add decay or "ringing" to the sound. I hate that I'll have to wait until summer to hear these playing stereo!
File Type: png ainoproto v3 spl 0¤ 500ms no smooth.png (125.8 KB, 38 views)
Old 9th April 2013, 09:19 PM   #129
Juhazi's Avatar
I have a life too...
On Saturday we visited our summer cabin by a lake in central Finland. A sauna bath was needed!
Old 10th April 2013, 07:56 AM   #130
lolo is offline lolo  France
lolo's Avatar
what? Are you that patient? I would blow a fuse waiting that long!
the spectrogram looks unusually good!
You Finns are really lucky to have so much unspoilt nature at your feet..
Aino gradient - a collaborative speaker projectHide this!Advertise here!
Copyright ©1999-2017 diyAudio
