Against the wall loudspeakers, pro's and con's?
Old 7th March 2013, 10:51 AM   #21
markus76 is offline markus76  Germany
Banned
Markus,
Just posted some thoughts about such a design here: http://www.diyaudio.com/forums/multi...ml#post3399569
Old 7th March 2013, 12:24 PM   #22
Elias is offline Elias  Finland
Elias's Avatar
As noted already, the wall reflection can be avoided in the freq range causing problems by using a large radiating surface for midrange. At high freqs can use a horn.
I can see only benefits of using on wall speaker. Only problem I can come up with is not all the rooms have available walls to place speakers, but often there are doors, passage ways, fire places, etc.
I also think the reason why there is practically no commercial wall placement speakers is exactly the requirement for large ratiating surface. All hifi speakers use tiny (5"-8") speaker elements, but here we would like to use 12" or bigger. Generally people are not used to that idea.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 7th March 2013, 12:45 PM   #23
Banned
Shipping small boxes from China is cheaper than shipping large ones
Old 7th March 2013, 12:47 PM   #24
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
well, ok, maybe just a few degr off axis
my listening position always end like this
Old 7th March 2013, 01:19 PM   #25
AllenB is offline AllenB  Australia
Originally Posted by markusA View Post
I'm willing to sacrifice pinpoint accuracy to some degree but waveguides seem to get the job done well enough without sacrificing too much.
I think so. As the primary motive behind them is to keep the sound off the nearby walls until it's been out in the room long enough not to matter, it's important that they aren't wasted by pointing them where they illuminate a wall. Most people choose to have them pointing out of a corner, also pulled out from the corner and crossing in front of the listener.
Furthermore the lack of reflections does, in my opinion, improve imaging accuracy although pinpoint isn't a word I'd use because it reminds me of the days when I needed to hold my neck still while listening to the really good bits. Good imaging makes you almost able to 'see' the performers' location and there shouldn't need to be any 'zeroing in on it'.
Old 7th March 2013, 01:38 PM   #26
Originally Posted by AllenB View Post
Good imaging makes you almost able to 'see' the performers' location...
not only almost, but actually does it, and very accurately too
it only depends on the source material
but there is a hatch
when you get used to it, anything else sounds wrong
Old 7th March 2013, 01:43 PM   #27
OT tinitus, did you decide to build your speakers with the two-way waveguides?
Old 7th March 2013, 01:50 PM   #28
how long ago was this ?
but yes, even if now different, it may still end that way
learned my lesson, and this time I built a pair, just in case...
Old 7th March 2013, 02:11 PM   #29
Tom Danley is offline Tom Danley  United States
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Up against the wall of science
In commercial sound some of our Synergy horns are mounted on boundaries because that eliminates the reflections from that entire plane.
While usually that is the ceiling or floor boundary, I have tried it in the home setting with walls and it works remarkably well .
The elimination of the reflections is possible because some of the loudspeakers are acoustically array-able, not just fit side by side physically. It’s funny, there are extremely few commercial loudspeakers which even though “array able”, do not join together into an inaudible seam while these do. When two of these are arrayed, you cannot hear a seam or the normal comb filtering one normally gets with two or more sources.
How?
They radiate the entire frequency range “as if” they had a single driver located at the very rear of the enclosure and so what emerges at the mouth is a large radius wave front and from a horn exit large enough to have pattern control to a fairly low frequency (very low in hifi speaker terms).
The horn also has the same wall angle as the cabinet wall angle and typically the horn is only a couple inches inside of the outer cabinet wall (making the acoustic separation small compared to where the horn pattern control is lost, thus, they act like one source)
The result is something like the graphic fig1 at the bottom of this page;
http://www.danleysoundlabs.com/danle...apped-Horn.pdf
Now, here one has a acoustic mirror image with the two speakers side by side. “IF” one takes one of the arrayable sides and puts it on the ceiling, floor or walls, one has a physical acoustic mirror image.
If you picture a wall boundary in place of the second cabinet (angled cabinet side against the wall), one has an analogous condition to a pair of sources. Take a TEF measurement of one on the floor like that and all you see is a lift in the low end below about 300hz. Because of the directivity and horn wall angles, standing in front of a pair, you are never in the pattern of both unless your exactly at the center and then, the sources are only a few inches apart and form an inaudible seam.
You can see from the measured polar plots of two that they do not interfere with each other and even down to 500Hz, the sound radiated to the rear and 90 degrees off axis is still -15 to -20dB down.
In a narrow room I have here, put the speakers on the walls like that made a HUGE improvement in the stereo imaging, much like being outside. The only issue there is the ideal is having the right speaker pointed at the left listening position and so on.
So, for a normal source (little or no directivty)over a boundary, if you want to radiate coherently as one source in time, the source can’t be farther than about 1/6 wavelength from the boundary. Picture that when the spacing has reached ¼ wl, the reflected sound comes back out of phase and cancels out the source (puts a deep cancellation notch in the frequency response).
It makes it easy to couple a woofer to a boundary and hard to couple a high frequency source to one. The wavelength at 20KHz is about 5/8 inch while 20Hz is 1000 times larger.
The Synergy horns work the same way, where two or more drivers interact, the acoustic spacing is always less than the critical distance set by the wavelength involved.
Best,
Tom
Bring back mst3k and futurama
Old 7th March 2013, 02:11 PM   #30
cbdb is offline cbdb  Canada
Soffit mounting is the standard in studios, with the front wall toed in. Removes the comb filtering and keeps the speakers on axis. A pain to do but that's what the big boys do.
Against the wall loudspeakers, pro's and con's?Hide this!Advertise here!
Audio analyzer software pro's/con's XEAGLEKEEPER Everything Else 1 10th January 2007 01:16 AM
help from pro's wanted. kmj Solid State 20 28th October 2004 04:54 AM
Pro's and con's of CCS circuit. G Solid State 6 30th September 2002 09:05 AM
Pro's&con's of PCB's Petman Tubes / Valves 4 5th July 2002 03:34 PM
