Who Likes Gradient? - Page 3 - diyAudio
Old 1st March 2013, 11:07 PM   #21
Patrick Bateman's Avatar
I used John Kreskovsky's U-Frame worksheet to compare the polar response of a midrange in a sealed box versus a U-Frame. Details here:
DIYMA Car Audio Forum - View Single Post - Improve Your Soundstage for $2
Sorry about the link to another forum, but I'm working on a car install right now and I think I might try cardioids for it.
Some things I noticed:
1) I was shocked at how small the enclosures can be. Even a cardioid that's small enough to fit in your hand had six decibels of rejection at 800hz
2) There seems to be some good reasons to use small enclosures for midrange cardioids, because of the peak in response that occurs at one quarter wavelength. So basically you 'push' the peak higher in frequency, and get cardioid radiation in the lower midrange, which transitions to dipole as you go lower in frequency
Old 2nd March 2013, 10:44 AM   #22
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by lolo View Post
Graaf, let's not be too fussy
who? me fussy???
it's just that ...when it walks like a duck, it quacks like a duck, it looks like a kind of a duck...
...then it must be a duck!
"high phooey and hystereo" - Yascha Heifetz
Old 2nd March 2013, 01:14 PM   #23
keyser is offline keyser  Netherlands
keyser's Avatar
Patrick Baterman, I can't find anything about the Vanderstien speakers online. I also tried Vandersteen, but I couldn't find any dipoles. Do you have some more information?
With respect to the tilted cardioid enclosure, I think it might be a good idea. The floor reflection is generally the earliest and possibly also the most detrimental with respect to coloration. Decreasing its level relative to the direct sound will decrease its effect. The downside is that the ceiling reflection becomes stronger - but the advantage of a weaker floor reflection may well outweigh the disadvantage of a stronger ceiling reflection.
What I don't get about the Gradient is its side-firing woofer. Definitely makes for a more attractive (slim) looking speaker, but I think it is detrimental for the sound quality. Not a choice I would have made. If the small footprint is important (which I understand), I'd rather use a couple more smaller front-firing woofers, perhaps in a U-frame.
Dutch & Dutch
Old 2nd March 2013, 01:20 PM   #24
Elias is offline Elias  Finland
Elias's Avatar
I believe the rotated dipole design comes from the philosophy the speaker is allowed to be placed against the front wall. This is a major thing in small european apartments.
Edit: Also the midrange cardioid speaks for this philosophy (no sound is radiated to wall behind the speaker)
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 2nd March 2013, 01:44 PM   #25
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Bass crossover of the Helsinki is 200 Hz. This should be completely in the modal region for smaller rooms. For the excitation of room modes it shouldn't matter much, if the dipoles are toed out 45° or toed in 45°.
Rudolf
www.dipolplus.de
Old 18th November 2013, 01:47 PM   #26
There *is* one interesting effect of having the dipole driver rotated 90 degrees:
1) When you rotate the dipole, you're listening in the null between the front and the back
2) In theory, the null is infinitely deep. In reality, the null is something like 10-20dB. Let's call it 15dB for the sake of argument
3) This means that when the ON AXIS sound is flat, the off-axis sound is 'bassier'
You can see it in the polars; note the rise below 300hz:
I wonder if this might allow the designer to deliver a sound that has some 'kick' without it sounding too bass heavy. IE, it might sound bass heavy if you're off axis, but on axis it sounds good.
Old 18th November 2013, 05:24 PM   #27
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Gradient helsinki is supposed to be placed near front wall and toed in liberately (45¤). Then bass is reflected from the front wall.
Here is original manual http://www.gradient.fi/Gradient/Down...I%20manual.pdf
Helsinki is a very exceptional speaker and it's bass is very sensitive to placement.
Gradient Revolution has dipole bass that can be rotated Revolution
AINOgradient speaker project
Gradient sub Williams Audio Swap Meet 0 10th October 2008 07:47 PM
Gradient sub Williams Audio Subwoofers 1 10th October 2008 01:34 PM
Who likes the sonic t amp? gvr4ever Class D 5 24th August 2006 07:15 AM
anyone likes for old times radio collections? digi01 The Lounge 6 9th August 2004 07:40 AM
Who likes vanessa Mae???? Andre Baptiste Music 1 28th February 2004 09:38 PM
Copyright ©1999-2017 diyAudio
