Who Likes Gradient? - Page 2 - diyAudio
Old 1st March 2013, 11:54 AM   #11
Banned
Originally Posted by Patrick Bateman View Post
But the Gradient does something clever, it basically distributes those reflections all over the listening room. So we still get four reflections, but they're not parallel to each other. More importantly, they're distributed in the time domain. So the 'floor bounce' doesn't occur at the same time as the 'ceiling bounce' or the bounce off of the wall.
You're describing a behavior that is common to most loudspeakers. It's not unique to the Gradient. Tilting a speaker (or driver) simply sends more energy in the room which decreases D/R ratio.
Old 1st March 2013, 12:19 PM   #12
graaf is offline graaf  Poland
graaf's Avatar
not really all over
in fact this scheme of pattern of reflections is misleading
please consider the directivity of the 6 inches midbas unit in this cardioid configuration and of the waveguided tweeter
for me it is quite evident that Helsinki deliberately uses (and increases the level of) the ceiling reflection and avoids (decreases the level of) the floor reflection to get the sound right
sometime ago in another thread someone called such a loudspeaker a ceiling flooder in an analogy to a "flood lamp" used for: "Indirect lighting, or uplighting, [which] create[s] a low glare environment by uniformly lighting the ceiling"
in the case of Helsinki there is much less energy reflected off the floor towards the listener and much more energy reflected off the ceiling towards the listener in comparison with a conventional loudspeaker
"high phooey and hystereo" - Yascha Heifetz
Old 1st March 2013, 12:21 PM   #13
graaf's Avatar
less? why?
not less - but in a different way, the pattern of the reflected sound is different
Old 1st March 2013, 12:44 PM   #14
Elias is offline Elias  Finland
Elias's Avatar
403 Access Denied
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 1st March 2013, 01:00 PM   #15
graaf's Avatar
Originally Posted by Elias View Post
403 Access Denied
why bawling?
it's just a typical bookshelf
Old 1st March 2013, 01:24 PM   #16
Elias's Avatar
Here is my hypothesis
Basically you can't eliminate reflections and diffraction, but the closer they are to the original impulse, the more they collapse the soundstage and reduce intellgibility.
On the other side, due to finite time-frequency resolution of the perception system the closer they are to the original impulse, the more they emerge as an inseparable entity.
The perception of cabinet diffraction depends on the time difference in relation to wavelength. This would indicate the diffraction effects be worse at highest freqs, but there also the time-freq resolution is poor (in terms of [dT]/[dHz]). For this reason for example high freq comb filtering goes mostly unnoticed.
- Elias
Old 1st March 2013, 02:44 PM   #17
lolo is offline lolo  France
lolo's Avatar
Graaf, let's not be too fussy. That a WG/Horn proponent admits the role of reflexions and hence good room use, is already a great thing for "us".
Old 1st March 2013, 05:01 PM   #18
Patrick Bateman's Avatar
Agreed, yes. Nothing magical about the Gradient, just saying that it's midrange configuration is a clever way of making the midrange act like a radiator that's a smaller size. The 'look' of the speaker reminds of some DIY experiment, but the measurements indicate that there's real engineering and a process of continued refinement in the design.
Old 1st March 2013, 07:36 PM   #19
Paul W is offline Paul W  United States
Paul W's Avatar
I heard the Helsinki a few years ago and, within dynamic limits, I liked them. For me, the Helsinki compensated for some of the limitations of simple stereo by shifting D/R response toward later room reflections. They provided a greater sense of envelopment.
Paul
Old 1st March 2013, 07:49 PM   #20
Banned
I'd think it's the other way around. If it's a working cardioid then the directivity at the lower end is higher than the same driver in a similar sized box.
Gradient sub Williams Audio Swap Meet 0 10th October 2008 08:47 PM
Gradient sub Williams Audio Subwoofers 1 10th October 2008 02:34 PM
Who likes the sonic t amp? gvr4ever Class D 5 24th August 2006 08:15 AM
anyone likes for old times radio collections? digi01 The Lounge 6 9th August 2004 08:40 AM
Who likes vanessa Mae???? Andre Baptiste Music 1 28th February 2004 10:38 PM
Copyright 1999-2017 diyAudio
