Effect of 5% Reduction in BR Volume. - diyAudio
Old 27th February 2013, 11:49 PM   #1
gassit is offline gassit  Australia
Question Effect of 5% Reduction in BR Volume.
Hello,
If you added extra internal bracing in an 85 litre BR cabinet which had been designed for a tuning frequency of 33Hz and an efficiency of about 93dB, would there be any adjustments required?
For example, would it be necessary to adjust the tuning frequency upwards (and, if so, by how much?) or stick with the original tuning frequency and suffer a modest decline in sensitivity?
Thanks for any input.
Old 28th February 2013, 12:39 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
How much "fill " do you have inside? If your fill is a lot, nearly full-up (Which you shouldn't) you could reduce the amount by half to compensate. It is my understanding that BR designs should have "fill" only lining the walls....but some completely fill the internal volume. Just throwing out ideas.....
__________________________________________________ ____Rick..........
Old 28th February 2013, 01:28 AM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by gassit View Post
Hello,
IMO 5% is a too small change to pay attention to...
b
Old 28th February 2013, 02:38 AM   #4
Richard,
Thanks for your reply.
There wouldn't be all that much fill.
Bjorno,
Yep, I think you're right-- nothing for me to lose sleep over.
Thanks everyone!
Effect of acoustic foam on Speaker enclosure Volume kchilaka Multi-Way 4 21st February 2013 12:00 AM
Cabinets effect (volume and baffle) on crossover otlnoob Multi-Way 13 29th October 2012 03:19 AM
Effect of enclosure volume deviation on vent tuning? rxwilson Multi-Way 2 7th January 2007 10:18 AM
effect on box volume of series vs parallel connection of speakers? wintermute Multi-Way 2 8th July 2005 01:14 AM
Effect of multiple drivers on ideal box volume hellomynameiswill Multi-Way 6 1st August 2001 02:26 PM
Copyright 1999-2017 diyAudio
