4-way Dipole speaker. - diyAudio
Old 27th February 2013, 06:04 PM   #1
Default 4-way Dipole speaker.
I recently finished a 3-way dipole speaker using a single Peerless XLS10 woofer in a 30cm deep H-frame, a 8" Seas L22RNX/P midrange and 10"Dayton WG loaded compression driver.
I am now moving on to a 4-way using, I managed to get another pair Peerless woofers so plan to mount them in a 45cm deep double woofer H-frame and cross over to the same Seas unit but with the addition of a Scanspeak 10F mid range and either a 19mm or 25mm tweeter.
I thought I would try and mimic another well know design but using different drivers and MiniDSP.
Below is how edge plots the design.
Old 27th February 2013, 06:10 PM   #2
dewardh is offline dewardh  United States
Similar to the LX521 "clone" I'm doing . . . I'll be interested to follow your progress.
Old 27th February 2013, 06:15 PM   #3
Well I have already drawn it out on a bit of 18mm MDF ready for cutting.
I am using the ABC-Dipole design spreadsheet to work out the EQ but will have to wait to make some measurements when they baffle is built.
I have a Quad 520 amp to power the 4 woofers, it should provide 150watts /ch into 4ohm.
Old 27th February 2013, 07:47 PM   #4
adason is offline adason  United States
adason's Avatar
you like that shape rich31td? to me its horrible, looks like coat hanger or something
Old 27th February 2013, 08:01 PM   #5
I do like it, It looks more interesting than a plank of wood which I have at the moment.
It kind of breaks the speaker up and looks less imposing, in my opinion.
I would have attempted the Nao Note II RS but it looks to complicated to make where as the LX521 is made up of straight cuts which I can cut with a hand held electric jigsaw, I hope.
Old 27th February 2013, 08:02 PM   #6
john k...'s Avatar
You will want to use the 4 ohm 10F as it has higher efficiency and will better match the midrange.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 27th February 2013, 08:14 PM   #7
Thanks John, thankfully I can get hold of either in the UK fairly easily.
I have decided on an 18" deep H-frame with two XLS woofers in each with a crossover to the midrange at 120Hz.
There isn't any problem in mixing driver materials i.e aluminum lower midrange with a fiberglass upper midrange?
Old 10th March 2013, 01:38 AM   #8
IMHO there are always much bigger fish to fry, but I wouldn't mix types if I had the choice... That said, if I had the drivers already then I'd give it a go (for science!).
Did I just sit on a fence?! :-p
Old 10th March 2013, 03:22 AM   #9
I see the LX521 as just as complex, if not more so... and quite a lot more $$$
Also, while I'm lucky with WAF, the aesthetics of the LX521 is a step too far in my house :-)
Old 10th March 2013, 11:32 AM   #10
The shape of the LX521 main baffle looks fairly simple to cut using a jigsaw, I also like the look of the Nao Note II RS but it looks to complicated for me to build, I have very limited wood working skills!
Small dipole speaker esuko Multi-Way 3 22nd March 2007 09:09 AM
Conearea in dipole speaker Jussi Multi-Way 25 12th August 2006 10:42 AM
Compute D for dipole speaker DougL Multi-Way 16 23rd September 2005 04:57 AM
Dipole Surround Speaker Design standingwave26 Multi-Way 9 2nd June 2004 04:05 AM
Copyright 1999-2017 diyAudio
