Altec 604E Super Duplex conundrum
Old 26th February 2013, 06:37 AM   #1
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Default Altec 604E Super Duplex conundrum
Lads...in a bit of a pickle here...
Had a set of Altec 604E Super Duplex units w/N1500 x/overs foisted on me today.
While one unit is tickety-boo the other unit has suffered the insult and injury of having some boob apply polyurethane to the backside of the surround ( I imagine in some misguided attempt to compensate for some form of voice coil rub).
Although the LF/MF unit coil tests ok for continuity the resistance reading of about 5 ohms is definitely off. The other non-handicapped 604E LF/MF coil measures at 11.5 ohms.
A play-test with a very low output signal applied to the LF/MF unit confirms almost zero cone excursion, but there is undistorted sound (I didn't dare subject the unit to anymore output as I didn't want to burn out the coil).
It's obvious this horrendous hack job must be remedied...so my question is how?
I am contemplating using acetone or some other agent to soften that gawd-awful foam, but am concerned that in doing so, I may likely damage the surround and/or the cone material.
Suggestions, insights?
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 26th February 2013, 06:45 AM   #2
Mods...could you edit my glaring header sp mistake? Thks.
Old 26th February 2013, 02:39 PM   #3
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
I think that driver needs a trip to GPA
http://www.greatplainsaudio.com/
Old 26th February 2013, 02:52 PM   #4
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yup - if coil is south , then no use of cleaning da mess on surround
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th February 2013, 03:03 PM   #5
Pano is offline Pano  United States
Pano's Avatar
Title fixed, thread moved to Multi-Way
Old 26th February 2013, 03:33 PM   #6
Gentlemen......GPA, of course, is the go-to source for Altec repairs if money was not an obstacle...but I am inclined by nature to investigate this a little further.
So my question remains...what agent could I use to soften and remove the polyurethane foam without damaging the original surround material and cone material?
Thanks, Leo
Old 26th February 2013, 03:35 PM   #7
Zen Mod. Are you saying that if the resistance reading on the LF/MF coil was higher than spec (instead of lower) that it might be salvageable?
Old 26th February 2013, 03:41 PM   #8
Zen Mod's Avatar
I'm saying that - if Rdc is erring more than 10% in any direction (from regular value ) , you can call that voice coil Dodo
so - as I understood - that one measuring 5 something is way off , so there is no point thinking about it's cone/surround condition - it needs complete recone
so Dave mention GPA
if other cone is in very good shape - leave it as is ; if it's in so-so shape - recone it , too
those spks are well worth your trouble
I think that boyz at GPA will check AlNiCos routinely
if all that is too much for ya , just send them to me , for proper disposal , free of charge
Old 26th February 2013, 10:24 PM   #9
weltersys is offline weltersys  United States
weltersys's Avatar
Looks like the foam was a too late botched attempt to fix a cracked surround.
The cracked surround probably led to a scraping voice coil, which partially shorted out judging by the resistance you measured.
Too bad.
Old 26th February 2013, 11:23 PM   #10
phivates is offline phivates  United States
Cured urethane foam is impervious to any solvent I know of. Acetone will attack most other older adhesives though; beware. Your DCR reading is odd, maybe the crossover is trashed and the two voice coils are paralleled?
Altec 604E Super Duplex conundrumHide this!Advertise here!
Altec 601 duplex and N-300E crossover hatrack71 Swap Meet 1 18th October 2010 03:10 PM
Altec 604e/Alpha 15 Open Baffle? dgator Multi-Way 13 7th February 2010 08:52 PM
Altec Lansing 617-8A; 12" Duplex; Ceiling Loudspeaker hoakd Multi-Way 5 14th July 2008 04:11 PM
Urei 801C Duplex Speakers lpd Swap Meet 1 21st January 2007 10:12 PM
Altec 606 Cabinets w/601 Duplex Drivers Benkev Swap Meet 3 22nd May 2005 06:09 AM
