Please check out my final circuit X/O with piezo
Old 31st March 2014, 10:50 PM   #21
weltersys is offline weltersys  United States
weltersys's Avatar
Tells me English is a second language to the writer, and they estimate larger value resistors attenuate the level more.
Old 31st March 2014, 10:52 PM   #22
krafty is offline krafty  Brazil
I will translate this datasheet, ok? Just give me a few minutes.
Old 31st March 2014, 10:54 PM   #23
weltersys's Avatar
Take all the time you want, turd polishing is not a useful pursuit :^).
Old 31st March 2014, 11:02 PM   #24
What do you mean? I meant datasheet. Not that other word.
Old 31st March 2014, 11:25 PM   #25
Here it is. Sorry to have posted with foreign words at first.
What do these numbers tell you now?
Old 1st April 2014, 02:16 AM   #26
Posting here a variation of the latest circuit. Moved R1 from paralel position to series (according to piezo datasheet, not frugal article). Shouldn't bear no audible difference, should it?
Old 1st April 2014, 05:37 PM   #27
weltersys's Avatar
That change would certainly measure quite differently, whether you can hear the change is another question entirely .
Old 1st April 2014, 06:43 PM   #28
Ok but theoretically, which one is correct. Parallel or series?
You said that without a resistor in series, it would never been seen as a driver, and it would crossover at 2000 Hz.
Does this move of the resistor changes anything and accomplishes what it is supposed to accomplish?
Old 1st April 2014, 08:52 PM   #29
weltersys's Avatar
1)Ok but theoretically, which one is correct. Parallel or series?
2)Does this move of the resistor changes anything and accomplishes what it is supposed to accomplish?
1) Both are different approaches, each is "correct", but will sound and measure differently.
2) You are dealing with drivers that probably have little in common with the "frequency curve response" you posted in #25, with an unknown impedance, I can't help you decide anything without knowing both. Measure (or listen) and decide which accomplishes what it is supposed to accomplish better for you.
Have fun, good luck!
Art
Old 2nd April 2014, 06:58 PM   #30
Ok, thanks. I will do the paralel one.
Please check out my final circuit X/O with piezoHide this!Advertise here!
can someone help me check this circuit? happyboy Solid State 50 12th August 2007 08:16 PM
one final check... nunayafb Multi-Way 4 16th August 2006 08:08 PM
check my simple circuit svokke Solid State 5 25th March 2004 07:19 PM
