2 Tube Vents to make equivalent from one
Old 25th February 2013, 11:39 PM   #1
krafty is offline krafty  Brazil
Default 2 Tube Vents to make equivalent from one
Hi.
In a enclosure with 4.1 Liters having a 17cm long x. 40mm diameter tube vent required... what length should I use if I need to switch the project to 2 tubes, one being 50mm and other 40mm diameter. (Just made a mistake with the enclosure and don't want to throw it away, these two holes).
Old 26th February 2013, 12:22 AM   #2
PeteMcK is offline PeteMcK
The Subwoofer DIY Page - Port Calculations
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 26th February 2013, 06:38 AM   #3
phase_accurate is offline phase_accurate
I would use only the 40 mm port and cover the other hole with something that looks nice (design yourself as label).
Simple as that.
If you were to use both ports they would get quite long and use up too much of your internal volume.
Charles
2 Tube Vents to make equivalent from oneHide this!Advertise here!
The 6P43P russian tube is a EL84 equivalent ?? aldovan Tubes / Valves 3 27th May 2007 07:57 AM
How can one make an equivalent circuit from parameter andy2 Multi-Way 1 21st March 2005 06:58 AM
Vents Vatos Multi-Way 1 6th April 2003 05:50 AM
Tube amp equivalent to LDC? Bolivar Tubes / Valves 1 4th February 2003 12:25 PM
online tube equivalent chart Bas Tubes / Valves 3 18th January 2003 08:52 AM
Copyright ©1999-2017 diyAudio
