Old 17th December 2003, 09:29 AM   #51
Default Experience ODIN - german Intertechnik version
Regarding the refined version of the ODIN , with special designed enclosures, this speaker seamed wonderful to me. I had the older version with Seas W17EX002 and without the Millenium tweeter. (look at the network).
I want to add, that this speaker sounded not as good with a big japanese amp, as it would do with a fine valve. The trebles had been to loud with that japanese FET AMP, and in first step u thought , i had to filter the tweeter 1-2db less.
But first i tried my valve SE AMP 2*1W and that showed me how really good that speaker was. -
The highs had been really good and the speaker played loud and deep. (I used and impedance filter for the valcve amp).
So my advise-use SE twice
greets
kai, ger
Old 17th December 2003, 09:30 AM   #52
Default ODIN . germany
here is on mor pic. Its ao non-parallel BR design for the cabinets.
greets to WWW
kai
Old 17th December 2003, 07:22 PM   #53
Pan is offline Pan  Sweden
There are a lot of SS amps that sounds perfectly fine with high resolution drivers... just donŽt try midfi receivers with feedback and sub optimal PS and parts though.
Some that works very fine is Pass Aleph, Gamut D200 or LC Audio Zapsolute. The latest generations of PWM amps would probably work very fine as well.
The bad rep ultra high resolution speakers have got is probably from using "crappy" electronics and a bad voicing of the speakers.
Stiff cones with low distortion motors is transparent... crap in = crap out, but feed them nice signals and a big smile normally appears on the listeners.
/Peter
Old 6th January 2004, 02:10 PM   #54
Thumbs up My impression of the Thor speakers
I built a set of Thor speakers using the Madisound speaker cabinets.
They are probably the best sounding speakers I have heard.
Inicially the speakers sounded a little constipated, but after a couple weeks the speakers loosened up (broke in) and just blew me away.
I often times find myself thinking "Wow, these sound damn good... Amazing...".
The bass is clean and extreamly tight. The room is a huge factor for the bass. I had to do a bit of speaker placement tweaking to obtain the desired results.
It would be virtually impossible for me to give these up. I did alot of in home trials of speakers and NONE compared to these.
A definite thumbs up from me!
Check out Madisound. They carry the full kit. I am happy with their kit, and more importantly their service!
Good luck!
Gav
Old 8th January 2004, 02:04 PM   #55
ChriSka is offline ChriSka  Norway
Default Re: My impression of the Thor speakers
Good luck!
Gav
Couldn't agree more.
How far away from your back- and sidewalls have you placed the speakers?
How much damp-material do have inside the speakers?
What kind of system are you running the Thor with?
- Chris
"The only thing neccesary for triumph of evil is for good men to do nothing" -Edmund Burke
Old 9th December 2004, 04:00 PM   #56
graks is offline graks  Norway
Send a message via MSN to graks
ChriSka: i see you have built the Thor speakers, i have the Thor kit from Eltek, and in a few days iŽll have the MDF. IŽll get it cuttet according to the measurements on Seas.no site. Do you have any hints/triks on how to veneer the cabinet? How are the rounded corners veneered?
Thanks, Mathis.
Seas Odin MK3 carl1009 Multi-Way 0 23rd March 2009 05:48 AM
Check my Odin X-over... graks Multi-Way 5 13th March 2006 10:21 AM
Could Thor/Odin be converted to ported fl. stander ? Jose_L Multi-Way 1 24th February 2006 09:51 AM
Seas Odin Mk3/Charis kit graks Multi-Way 8 8th March 2005 08:04 AM
Page generated in 0.07937 seconds (83.88% PHP - 16.12% MySQL) with 11 queries
