Sony SS-AR2 Top and Bottom Bracing - diyAudio
Old 21st February 2013, 01:13 AM   #1
gassit is offline gassit  Australia
Default Sony SS-AR2 Top and Bottom Bracing
Looking at the attached photo of the Sony SS-AR2, you'll notice that there are wood braces at the top and bottom of the cabinet.
Are these braces useful, either theoretically or in practice?
Thanks all.
Old 21st February 2013, 01:18 AM   #2
adason is offline adason  United States
adason's Avatar
yes
Old 21st February 2013, 01:19 AM   #3
Don't be shy...tell me more please.
Old 21st February 2013, 01:57 AM   #4
I doubt you'd be able to hear a difference with those. Those panels are relatively small given their span and thickness and that type of reinforcement only improves rigidity in one direction.
Old 21st February 2013, 03:09 AM   #5
Hmmmm...
Old 21st February 2013, 03:59 AM   #6
Instead of small I meant to say stiff. Oops.
Anyway, it could be that they added those pieces so as to fine-tune the internal volume.
Old 21st February 2013, 04:58 AM   #7
Good point about fine tuning the internal volume.
Slightly off topic, but if you knew that there was an audible panel resonance at 125Hz with this speaker which panels would you be looking at to find the culprit?
Old 21st February 2013, 05:20 AM   #8
If you knew the dimensions and MOE, you might be able to calculate it but it certainly is a lot easier to use an accelerometer.
Old 21st February 2013, 05:33 AM   #9
Dimensions: 11" x 37.5" x 16".
Don't know what MOE is but I'm familiar with Curly and Larry.
Old 21st February 2013, 02:13 PM   #10
adason's Avatar
i always do that, glue all the leftover pieces of wood on the inside of speaker panels...I am not sure if it helps theoretically or practicaly, but I do it anyway. What else can you do with odd cuts of wood? You can burn it, throw it away, or use it to make the box heavier and less resonant.
I'm looking for Sony midrange pair (from high-end ss-g7 / ss-g9) vintnt Swap Meet 2 22nd April 2011 09:23 AM
Pin numbering, viewed from bottom or top? flysig Tubes / Valves 4 1st June 2009 09:22 PM
Best way to connect top to bottom minh_827 Multi-Way 6 6th September 2005 05:40 AM
Is this top of bottom view of 12AX7 / 6N30P? Petter Tubes / Valves 6 9th September 2002 01:50 AM
Copyright 1999-2017 diyAudio
