#21 |
I plan to remove all the components from the boards. I am going to try using a small circular saw blade on my Dremel and cut on both sides of the leads on the back of the board. I should be able to lift up the piece of foil that is holding the lead to the board.
I am plotting out the schematic and am confused by the fact that the pot that is marked 'Woofer' is not connected into the woofer circuit at all. It is part of the midrange/tweeter circuit. What? |
#22 |
There are mid and tweeter L-pads it is that simple.
Nothing to do with the woofer. From what I remember the boards had a lot of lacquer or silicone on them don't remember exactly. I would clean them as best as you can, and desolder the parts that need to come off. You might need a high power (40W) iron to heat these large connections. I would only use a dremel tool to clean up any burned areas if there are any. I would not remove any inductors, but test them at least for DC resistance to try and see if any are badly shorted - I doubt it. Also, test the L-pads since I think these speakers were over driven. |
#23 |
I have attached a photo of the back of the board where all the connections are located. You can see where the leads have been bent over and a copper foil with aluminum backing has been placed over them to make the circuits. Then the whole board has a coating on it, to seal it. Since the aluminum side is up, soldering does not work. It would be easier to just make a new board and wire all the connections. The question is whether to use a blank board and drill the holes or use a pre drilled circuit board and fit the components. In that way, I will have solder pads built in. I feel that, in order to properly test all the components properly, I need to remove them from the board.
Joemusic |
#24 |
That looks like a circuit board to me, tinned copper.
What makes you think it is aluminum. It is very difficult to solder to aluminum. I would guess that if "soldering does not work" as you say that it is because you do not have a large enough iron or there is too much contamination from whatever was used to seal it. You might try acetone (nail polish remover) or Goo off and a wire brush outdoors or in a well ventilated area to remove the sealer. You really only have to clean the areas where the leads are bent over and you might want to try a very small wire brush on the dremel tool. I'd like to see a picture of the other side if you have one. Last edited by PB2; 6th March 2013 at 02:46 AM. |
#25 |
This board is made up of layers. You have a bare circuit board that has the holes drilled through it . They, then placed the components on the front side and pushed the leads through to the back where they bent them over and cut them about a 1/8" long. Once all the leads are in the back, they cover certain areas with a foil that is copper on one side and aluminum on the other. These made the circuits. Then they coated the whole thing with a sealer.
I have remove a small piece of the foil by scrapping the coating off and then, using a razor blade, cut a square out of the foil and lifted it off the board. In essence, making a simple circuit board. There are place where they have soldered wires on top the foil; but, I think that they have, in some way, removed the aluminum layer and soldered to the copper. As for the drivers affected, I have one blown woofer and all the rest test OK. My plan is to make a PCB that will make the same connections as the foil did. Joe Last edited by joemusic; 6th March 2013 at 08:00 PM. Reason: Add photo |
#26 |
Looks like they used too low a wattage on the resistors , no wonder they finally burnt out and YIKES could they have possibly crammed more components CLOSER together? I would make a larger board maybe out of peg board and give myself plenty of room for spacing out things.
#27 | |
The leads are clearly bent over on TOP of the metal traces, and were probably all soldered to it. It looks like it is just standard tinned copper. It looks like a standard PCB fabrication, where the leads were pushed through from the top, bent over against the traces for mechanical strength and for a larger electrical connection area, and soldered to the tinned copper traces. (I don't quite understand why they also put traces on the component side. Are any of the leads soldered on the top side? Are the trace patterns the same everywhere, on the top and the bottom of the board?) What makes you think they applied some sort of bi-mettalic foil AFTER the leads were pushed through the holes and bent over?? The leads wouldn't even be soldered to the traces, that way! And there is no way they could have used a crimped-on sheet of metal with some sort of adhesive to hold it on, and had good-enough connections. Maybe you should try desoldering some of the leads, on the back, so you can see that there is a hole in the silver tinned trace, where each lead comes through it. Last edited by gootee; 7th March 2013 at 12:36 AM. |
#28 |
While you're at it, you could replace the electrolytic caps with polypropylene, from someplace like parts-express.com or madisound.com . They will be much larger but might sound better, and, mainly, will last much longer.
#29 | |
It seems you're making this WAY too complicated. If they were my speakers, I would simply assume the coils are OK, because they almost never go bad, then lift one end of each of the resistors and measure them to make sure they are OK, and then simply replace the five electrolytic caps, either with new non polarized electrolytics, or film if you want to spend money on something you probably won't be able to hear. Then hit the L pads with with Deoxit, rotate the hell out of them until you get tired of it, then hit them with Fader Lube. Test it simply by hooking up a mid range driver to all three outputs with the crossover connected to an amp playing music or voice and be done with it. Besides waiting for the replacement caps it should take about half an hour. Finding a matching replacement woofer is what you should be spending your time on. Last edited by audiomagnate; 7th March 2013 at 04:39 PM. |
#30 |
I will be dissecting the lead to board attachment in the next few days. I have the small circular saw blades for my dremel and will slit the 'foil' on either side of the leads and lift it off. I will photograph it as I go, so that we can actually see what Vandersteen did. I do agree with you that some of the components are too small in capacity. I was thinking of using a large resistor in place of the three smaller ones that burnt out.
Joemusic |
| Vandersteen 2ce crossover repair | chriso1 | Multi-Way | 27 | 12th April 2013 11:25 AM |
| Vandersteen 2ci | Ty_Bower | Swap Meet | 2 | 3rd April 2011 05:47 AM |
| Looking for Vandersteen 2ci woofer for sale | marara04 | Full Range | 0 | 18th March 2011 11:49 PM |
| Vandersteen 2ci speaker parts | olyken | Swap Meet | 1 | 13th October 2008 10:50 PM |
| Vandersteen 2ci crossover repair | olyken | Multi-Way | 1 | 27th September 2008 04:00 PM |
