miniFAST Boombox Build
Old 19th February 2013, 10:57 PM   #11
IG81 is offline IG81  Canada
IG81's Avatar
Originally Posted by soren5 View Post
By the way, which Peerless are you referring to? Couldn't find that model number you wrote.
The official part # might be 830875 then. I used the number listed over a Solen.
IG
Old 19th February 2013, 11:11 PM   #12
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
So when you say "yes" I assume you mean for the better? Could it be that the FF85WK simply don't behave very well in a sealed enclosure?
Yes, performs better. "not open" typically is reflection coming back thru the cone. THe uFonkenSET for instance is more open than the slightly smaller uFonken, the TLs are larger volume and lower back pressure.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th February 2013, 11:13 PM   #13
frugal-phile(tm)
planet10's Avatar
Yes, that is the one we are using. Relatively expensive when using multiples and likes a surptisngly large box, but gave far more than expected in the prototypes.
dave
Old 19th February 2013, 11:16 PM   #14
soren5 is offline soren5  Denmark
IG
Could be worth a try. Only problem is it's 8 ohm. The woofer should ideally be 4 ohm in a 2.1 like this. Makes it easier to find a digital amplifier (4 single-ended: 1 for each full-range driver and 2 bridged together for the woofer). Thanks for the suggestion though.
Old 19th February 2013, 11:25 PM   #15
dave
Interesting. So, if I made TLs a la Tysen for the Fostex in this application, could they then have similar sized enclosures (1-1.5L) and a length of only 15-17cm?
Old 19th February 2013, 11:40 PM   #16
chris661 is offline chris661  United Kingdom
chris661's Avatar
That woofer will stand ~700Hz cleanly, if its anything like its Neodymium sister. I wouldn't call it "slow" by any stretch.
If you're using some signal processing (or if you can plug a laptop in), apply a little treble boost and see what you think.
FWIW, I wasn't impressed with the budget Dali speakers I've heard. Call the Fostexes correct, and say the Dalis are too bright
Chris
Old 20th February 2013, 12:14 AM   #17
IG81's Avatar
I never heard the driver, it was a mere theory. Good new for the OP then!
Chris
+1 Afterall, how could a commercial (yuck - dirty word) product rival anything DIY?
IG
Old 20th February 2013, 12:49 AM   #18
frugal-phile(tm)
planet10's Avatar
In a boombox this woofer is probably not a good choice due to the volume it requires. When i was working on my latest MTM (with FF85wk) 2 of the Peerless would have needed 30 litres, the 2 SilverFlute W14 i ended up using needed 10litres -- the SF are available in both 4 & 8 ohms. The W14 are cheaper IIRC too.
dave
Old 20th February 2013, 12:52 AM   #19
frugal-phile(tm)
planet10's Avatar
The sub enclosures & TL in my last ate up 3 litres and were ~26 cm long. The TL is not very critical in dimension but erring on the large size and longer line is probably better... it is dominated by the damping, but larger gives more room for damping.
dave
Old 20th February 2013, 11:48 PM   #20
I've looked at the SilverFlutes before, but they don't seem easy to get hold of in Europe.
miniFAST Boombox BuildHide this!Advertise here!
First Boombox Build henwy Parts 5 19th June 2015 10:52 AM
A Slackers Boombox Build spwalek Construction Tips 4 27th January 2013 10:40 PM
Sanyo Boombox Build* funkdoktor Construction Tips 1 26th September 2012 05:15 PM
Another (small) Boombox Build lost eden Class D 30 4th January 2012 10:14 AM
boombox re-build NED 209 Class D 21 26th March 2008 06:31 PM
