#11 | |
-Pete |
#12 |
I agree with Pete. I found you could really "dial in" just the right amount of baffle step. It's really beneficial to be able to fine tune this important area. I'm trying to figure out how to do this in a balanced system now since I am reconfiguring my setup.
#13 |
placing the speaker aginst the wall helps...................
or use a wide baffle (2' or more, I don't use baffle step). And it costs nothing. You could use a 10 band equalizer to add some lift. I'm a fan of a baffle step woofer (with an inductor on it only), but that raises the price, and can be tricky to dial in. Even then, place it elsewhere and you are back to tweaking. |
| When to use baffle step compensation? | tmblack | Multi-Way | 28 | 6th December 2008 12:39 PM |
| Baffle Step Compensation Adjustment | wigginjs | Multi-Way | 17 | 31st January 2008 06:44 PM |
| JX92S and baffle step compensation | neil_kaye | Full Range | 12 | 6th December 2006 12:20 PM |
| Baffle Step Compensation | Khron | Multi-Way | 4 | 16th April 2006 08:23 PM |
| Passive baffle step compensation | noodle_snacks | Multi-Way | 5 | 10th October 2005 06:20 PM |
