Seas MU10RB-SL or Scanspeak 10F/4424G?
Old 19th February 2013, 11:11 PM   #11
Jay1111 is offline Jay1111  United States
Originally Posted by tvrgeek View Post
Because they don't actually work like that. That darn thing called physics again. But they are legitimate 5K midranges, which are few and far between. Go ahead and try it, but leave room to add a tweeter later as you will want it.
Im confused. They dont actually do what the measurements show they do? Multiple sources have shown the same high frequency performance on and off axis.
Old 19th February 2013, 11:38 PM   #12
454Casull is offline 454Casull  Canada
You're saying that the 10F/4424G00 has the same off-axis performance that a 1" or a 3/4" tweeter does?
Old 20th February 2013, 12:12 AM   #13
Looking at the Blue (on), Green (15 degrees), and Red (30 degrees), it compares fairly well to 1" dome tweeters.
Here's a Seas 27 TAFNCG for a quick example
Old 20th February 2013, 12:36 AM   #14
Face is offline Face  United States
Face's Avatar
Yes, I've worked with the 10F, the 8ohm version though.
The difference between the two drivers above will be very audible.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 20th February 2013, 01:25 AM   #15
SEOS 12, DE250 (7.5 degree increments). Outside of the outstanding CD response, nothing special or extended about the high frequency extension. Arguably worse then the SS...
I'll definitely test the SS out before I plan a mega build around it, but I'm still not seeing where its performance is poor.
Old 20th February 2013, 03:31 AM   #16
ScottG is offline ScottG  United States
It isn't a poor performer, in fact it is excellent. The dispersion is only slightly more directive than a typical 1" tweeter, and most of that is beyond +/- 30 degrees.
I remember JohnK questioning his own original Note's design making use of the Neo 3 PDR.
Now as far as sound quality.. I believe that Planet 10 didn't quite think that they sounded as good as some of the smaller Fostex drivers, but I'm even less sure on the conditions that formulated that opinion (..if indeed there was one).
perspective is everything
Old 20th February 2013, 03:41 AM   #17
That's what I was thinking. My intended use would be crossing 500-1khz to some kind of serious woofer setup. Outside of a huge waveguide, this looks like one of the only drivers well suited to the application.
Old 20th February 2013, 03:49 AM   #18
Pretty much a "FAST" design.
You should probably base the woofer's crossover in conjunction with baffle step loss. A more narrow baffle, higher effective crossover freq. (..and vice-versus).
If you need a bit more "air" because of increased dispersion beyond +/-30 degrees you could always add-in a rear facing tweeter with a very high freq. high-pass filter.
You might want to "ping" Dave/Planet10 on this and get his thoughts on this driver and other similar drivers as well.
Old 20th February 2013, 04:27 AM   #19
gainphile is offline gainphile  Australia
gainphile's Avatar
Where these 4" drivers will fail as a "tweeter" are distortion and stored energy. Just like any other full range of similar size.
http://gainphile.blogspot.com
Old 20th February 2013, 04:39 AM   #20
I forget my history but can't stored energy simply be EQed out since it is linear distortion?
Also, with the two charts Jay provided we can see that the SS is 7 dB less intense than the 1" tweet at 10 kHz. With the following waveguide at least everything can be EQed flat with matching off-axis.
Seas MU10RB-SL or Scanspeak 10F/4424G?Hide this!Advertise here!
Scan-Speak Discovery 10F/4424G / 10F/8424G BHTX Full Range 12 25th January 2017 08:32 PM
ScanSpeak 10F inrank Full Range 64 9th September 2012 10:55 AM
Wanted Seas 10F-M H084 paul_peraic Swap Meet 4 1st July 2012 11:32 PM
FS: Scanspeak Discovery 10F/8424G00 4" Midrange pair matevana Swap Meet 1 26th October 2011 03:12 PM
Mid ss 10f/4424g: Wanted tweeter with a small flange Makc Multi-Way 7 22nd October 2010 06:36 PM
