#31 |
hey, dunno. good question, never thought about it.
heck, just had a minutes thought, no good answers popped up! History? 'the way things have always gone'? OR, just take a design that has already worked out a driver selection that would work together, get your measurement gear out and put in the filters that give you what you want? Flat on axis, whatever. anyway, I think others might have some ideas on that. good question. |
#32 | |
)I hope so. Could you give me a bell then? (I'm subscribed to your thread) |
#33 |
Not sure which thread you mean allen, but yeah I should remember when we start adding up 'who is coming this year?'. A dim spark should ignite from somewhere.
we usually end up 'testing something' each year, next was supposed to be 'can we really hear cap differences in a power amp', were going to do a blind test with some of the more vocal 'I can hear differences between wire types in an amp' but they seem to have spat the dummy and it's looking tenuous. I'm not that upset to be frank, the idea of having ten golden ears walking around kinda gave me the heebie jeebies. SO, long story short, if you have any ideas of what might make an interesting thing to investigate this year throw em into the pot. I am thinking 'why not just a good old dac comparison'...but done blind via instant switching from the LP. That might throw a spanner into the works of the 'oh my god, every dac is sooo different' and the true relative differences start to emerge. |
#34 | |
As Bennett Prescott puts it, "the DSP tower of Babel". Simply put, if I design a crossover using "X" DSP, and a DIY uses those settings on "Y" DSP, they will not measure or sound the same. The differences may be subtle or gross, the more filters employed the farther off the end results will be. Even different models under the same parent company often don't match up. In addition to "Q" variations, there are plain stupid design errors- for instance the DBX DriverackPa inverts polarity between input and output, no big deal when used alone, but the DriveRackPA+ inverts only the midrange outputs. If someone correctly designed a crossover on that unit, the midrange would be reversed polarity using the same settings on any other "normal" DSP. Art Last edited by weltersys; 21st February 2013 at 09:51 PM. |
| DAC output filter...passive or active? | soundnovice | miniDSP | 4 | 14th June 2012 10:05 AM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| passive filter for sub | moi | Multi-Way | 34 | 28th July 2003 02:12 PM |
