3 way centre speaker crossover. W(MT)W - diyAudio
Old 17th February 2013, 03:50 AM   #1
shmb is offline shmb  Australia
Default 3 way centre speaker crossover. W(MT)W
Hi all,
I'm trying to design a crossover (basically by ear and trial and error) for a 3 way centre, W(MT)W consisting of two Vifa P17WJ-00-08 woofers, one Peerless 830870 Midrange and one Vifa D25AG35-06 tweeter.
I'm using a reference speaker system to help with voicing.
The upper x-over point is no so much an issue, as its more or less just like a conventional vertical 2 way.
However, the lower x-over point is giving me headaches. Basically, I'm trying to achieve the best horizontal tonal consistency as that's important to me in this application.
I've read that this type of 3 way centre is the way to go here, as the lower crossover point can be set low enough to avoid major issues.
It definitely works much better that a 2 way (WTW) one I tried last year with the same drivers. (minus the Peerless midrange)
However, I'm still not happy enough, so I'm trying to see if anyone can possibly help me with this.
A few general questions:
What's the ideal x-over frequency here for my baffle size, driver spacing etc? (I'm guessing around 500Hz or less????)
Is it best to use a 12db/oct or 6/db/oct slope?
Midrange polarity reversed or in phase with woofers?
I realise these may be too general to answer easily and trial and error is the best way to find out, but I'm just trying to gather whether there's a tried and true way of doing this that anyone may know of.
A (dodgy) drawing of the front baffle arrangement is below.
Speaker drivers datasheets are here:
http://www.madisound.com/store/manuals/p17wj-00-08e.pdf
http://www.essentialaudio.com.au/pdf...ess_830870.pdf
http://www.d-s-t.com.au/data/Vifa/D25AG-35-06.pdf
Any help is appreciated.
Thanks.
Old 17th February 2013, 03:56 AM   #2
Jay1111 is offline Jay1111  United States
Textbook filters will not account for complex impedance curves, and you will likely never be happy in the long run.
A completely custom simulated crossover could be done based on the manufacturers posted measurements and TS parameters. It might not be 100% accurate, depends on how far off the data is, but it is 100 times better then textbook filters.
Old 17th February 2013, 04:02 AM   #3
100% agreed, and that's why I'm doing it by trial and error, off the shelf stuff has never worked for me.
I guess I'm just trying to determine if there is a particular slope or x-over freq that may be more suitable for this arrangement. (for horizontal consistency.)
I can do the fine tuning but I'm looking for a general direction, if that makes sense.
If that's not possible, then so be it.
Old 17th February 2013, 04:07 AM   #4
Its going to be extremely hard to cross the woofers over without knowing what is going on, large inductors/caps have a peaking effect.
Old 17th February 2013, 05:11 AM   #5
Moondog55's Avatar
I have read that the woofers in this arrangement are best used in an angled baffle ( 45 ) and crossed as low as possible This may also work better with the mids and uppers in MTM configuration
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 17th February 2013, 06:55 AM   #6
balerit is offline balerit  South Africa
balerit's Avatar
Is this for speech or singing? This is an Audax setup by Joe D' Appolito and they crossover at 400 and 3500 Hz, box tuned to 50 Hz.
Old 18th February 2013, 12:40 AM   #7
system7 is offline system7  United Kingdom
system7's Avatar
Really couldn't think about this much without a schematic of your current trial crossover. The volume of the mid enclosure and bass enclosure is relevant too. Is it reflex?
2X 6.5" polycone bass and a 4" polycone mid it seems. Fairly regular sort of tweeter.
Troels has a 3-way design, Mark 21, not a million miles away in drivers and I don't see an issue in rearranging it as D'Appolito:
Mark 2115
Are you somewhere near those values? You really need to explain yourself clearly. This is way too much homework as it stands.
Best Regards from Steve in Portsmouth, UK.
Old 18th February 2013, 12:47 AM   #8
Dissi is offline Dissi  Switzerland
A simulation of the horizontal off-axis response of the woofers helps to answer your questions:
A crossover frequency of 500 Hz is already critical, 300-400 Hz seems to be on the safe side. A 2nd order low-pass filter (12 dB/oct) is inevitable to compensate the rising frequency response caused by the baffle step. The midrange polarity is always reversed to the woofer.
As Jay mentioned, the lower crossover of a 3-way is very tricky, and you have little chance to get it right without simulation or measurements. To make a simulation and propose a crossover, I need some additional information:
- cabinet depth and wall thickness
- sealed or vented, vent dimensions
- volume of the midrange housing
- current crossover (any reusable components?)
- distance and vertical displacement of the listening position (related to the tweeter)
Old 18th February 2013, 07:28 AM   #9
Thanks for the replies so far, .....interesting.
The system above looks to have different values to mine, but not massively different, they could be worth a go.
To try and answer the questions:
Midrange volume is approx 7L sealed.
Each woofer has a separate volume of approx 12L, each with a 5cm dia port 28cm long. (although the port length is not necessarily final yet)
Cabinet depth is 34 cm, all built with 18mm thick MDF.
It is positioned below the TV, so is below ear level. From tweeter level upwards is important.
Horizontally, 45 degrees would be a minimum, even up to 60 would be great if at all possible. But I know that could be pushing it.
I originally had the woofers wired in series as I thought they were too efficient when used in in parallel for the other 2drivers.
Below is one crossover schematic I used for a while which sounded quite good to my ears.
However since then, I've tried 12db/oct of various combinations, reversed 'mid' and 'tweeter' polarity, and then even went back to parallel but that throws off all the values and sensitivities, so need to start again, so that's when I decided to get on here.
Hope this helps a bit more, but its sorta hard to explain.
Old 19th February 2013, 12:37 AM   #10
shmb,
Do you already own the drivers?
MTM vs MT for center channel speaker dannyjmf Subwoofers 4 13th July 2010 03:01 PM
MT 27 Speaker & Kits Downtune CSS 1 9th February 2010 07:50 PM
centre speaker garymtb Multi-Way 24 7th June 2007 12:30 PM
Audax Centre channel crossover for midrange jtfoo Multi-Way 6 30th March 2005 01:21 PM
Help with Centre Speaker andrew Multi-Way 6 2nd May 2002 08:52 AM
Copyright 1999-2017 diyAudio
