My amp gets warm...
My amp gets warm...
Old 21st November 2003, 03:08 AM   #1
Jye is offline Jye  Australia
Jye's Avatar
Default My amp gets warm...
Hi everyone,
Iíve just finished my latest project a sonosub, which I am totally happy about , but the amp remains warm when it is on standby. The amps a 350W from Jaycar and I would like to know if this is common, or should I be trying to get a replacement .
For those how would like to know am using a Peerless 12Ē XLS, two 100mm ports 670mm in length and the volume of the sonotube is 112L. Iíve been breaking the driver in over the past few days and will then play around with the port length a bit. And for a bit of extra weight to reduce vibrations the inner top and bottom have been lined with 20kg a lead. Iíve posted a few more pics on my web page (which is more of just a photo gallery).
Cheers
Old 21st November 2003, 05:04 AM   #2
speekergeek is offline speekergeek  United States
I have a parts express 250 watter and it stays pretty warm when on standby too. i think it is the transfrmer or something.
Old 21st November 2003, 06:09 AM   #3
The Paulinator is offline The Paulinator  United States
Yeah, I have a 150 watt I pulled from a Radio Shack sub and it does the same.
Is that enclosure lined with felt or something? That sure is sharp looking! Kudos!
Old 21st November 2003, 06:27 AM   #4
Volenti is offline Volenti  Australia
With the amp on standby you still have current idling through the transformer, which is where the heat that you feel is coming from.
Old 21st November 2003, 08:08 PM   #5
autoexec is offline autoexec  United States
where do you get the cylinder wood
hardware store, or is it more of a specialty thing
Old 21st November 2003, 10:17 PM   #6
Jye's Avatar
Thanks guys, I knew there would still be current flowing through the transformer but I had no idea it would create that much heat .
Cheers
Old 21st November 2003, 11:53 PM   #7
Jye's Avatar
Hi Autoexec,
The tube is called Formatube (or Sonotube in the USA) and is used for casting concrete. The below link has heaps of examples,
http://members.tripod.com/~terrycthe...um/page12.html
As for a supplier the only place in Brisbane is Boral, but before I found that out I rang EVERYONE.
My amp gets warm...Hide this!Advertise here!
punch 60 dsm getting warm ben04srt Car Audio 5 3rd June 2009 10:37 PM
saa7220 gets warm?? jnewbold Digital Source 13 28th October 2008 09:11 AM
Help!!ETD core warm Xaudiophile Power Supplies 9 19th May 2005 04:49 PM
SI T-amp warm-up? irss Class D 3 8th April 2005 11:40 PM
