Design: Horn High Sensitivity Speakers
Old 16th February 2013, 05:22 PM   #11
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
some low cost HF drivers.
BMS 4554 1,4" $202,-
Faital PRO HF144 1,4" $298,-
Eighteensound HD1480T $312,-
Faital PRO HF204 2" $307,-
Eighteensound HD2080T $335,-
Selenium D3305Ti DPD $159,-
http://www.jblselenium.com/marcas/pr...114&idLinha=40
B&C DE610-8 1.4 $200,-
Radian 745PB 1,4" this looks very decent for the money $235.-
http://radianaudio.com//components/c...45pb_835pb.pdf
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 16th February 2013, 05:41 PM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
would like to try this one
FaitalPRO | HF Drivers | HF107
Old 16th February 2013, 06:17 PM   #13
Helmuth's Avatar
I think selenium is easy available in chile.
the 15WS600 good bas extension -6dB 28Hz 96-97dB 1W. $185,- bottom price imo.
Selenium 15WS600 15" 600W Woofer 264-393
Old 16th February 2013, 06:35 PM   #14
Helmuth's Avatar
A 1" driver will reduce the cost a lot, only problem poor mid response there are nice ones that do 800Hz.
Like the popular 1" DE250 $128,-
http://www.parts-express.com/pe/show...number=294-605
Here a nice horn for 1" $200,-
AutoTech Iwata-600 - Horns DIY Sound Group
Will look good with 15" woofer about the same with.
Then one speaker would cost $513,- drivers and a horn for 2 way.
Old 16th February 2013, 06:49 PM   #15
Helmuth's Avatar
I think that the 2" fatialpro offers very good low response usable down to 500Hz with a 24dB filter. For hifi low power amp input a second order filter will also do. Will make a great precise midrange response.
Faital Pro HF204 - Faital Pro HF204 2" neodymium high frequency compression driver with a ketone polymer diaphragm. Faital Pro HF204 HF drivers available here at US Speaker.
This to gather with the 15WS600 woofer a 97dB system 28Hz-20000Hz XO 500Hz. And the state of the art JMLC 2" horn. Point source 500-20000Hz
For $605,- 2"driver fatialpro, jmlc400, and jbl selenium 15W600.
Mid-response of the 15WS600.
Design: Horn High Sensitivity Speakers-schermafbeelding-2013-02-16-om-20-03-15-png
File Type: png Schermafbeelding 2013-02-16 om 20.03.15.png (70.8 KB, 1002 views)
Old 16th February 2013, 06:58 PM   #16
if you do that, wouldn't its own acostic-roll-off cause it to roll off earlier...and maybe even faster than 24db
which 'could' lead to phase ....
Old 16th February 2013, 07:07 PM   #17
Helmuth's Avatar
This is right, then you can filter the woofer steeper so you can match the phase with the horn driver works also fine with my own loudspeaker.
With the steep fillter the woofer can not mess up the clear tight midrange of the HF-driver. A win win situation isn't that great.
Old 16th February 2013, 07:17 PM   #18
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by charly chile View Post
For measurements I have a calibrated berihnger mic with a phantom power soundcard. I have been playing with Holm Impulse software.
Then you are well on the road to enlightenment. Good for you.
Whatever drivers and horns you chose to use, measure, listen, tweak, measure, listen tweak, etc, etc. It can take a long time.
What works for me may not work for someone else, but we can give advice. For example: Bear likes the horns turned on their sides, I do not. I like a Bessel 4th order acoustic slope for my crossovers, some people don't. You'll have to find what works best for you.
You know that if you go SS amp and use the miniDSP on the 18", you could keep it open baffle. You might like that with the horns.
Take the Speaker Voltage Test!
Old 16th February 2013, 08:25 PM   #19
Helmuth's Avatar
A other advantage of a 2" driver to a 1" is the shorter horn.
This is desirable to prevent any horn coloration of the response.
Old 16th February 2013, 09:54 PM   #20
Helmuth's Avatar
For highest sensitivety frontloaded midbas horn with the 18sound 15mb606, and bas-reflex port for bas extension.
here a nice horn design from volvotreter.
Click the image to open in full size.Click the image to open in full size.
Sensitivety here is for 1pi situation. 108dB 1 W
Design: Horn High Sensitivity Speakers-schermafbeelding-2013-02-16-om-22-43-39-png
Design: Horn High Sensitivity Speakers-schermafbeelding-2013-02-16-om-22-43-54-png
103dB in 2pi radiation.
Design: Horn High Sensitivity Speakers-schermafbeelding-2013-02-16-om-22-52-57-png
Design: Horn High Sensitivity SpeakersHide this!Advertise here!
Phase plug design for high-directivity horn Spatz Multi-Way 2 4th October 2014 07:34 PM
How do I design a back chamber for a horn speakers. djn Multi-Way 15 27th November 2010 04:40 AM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 01:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 05:23 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 12:30 PM
Copyright ©1999-2017 diyAudio
