Design: Horn High Sensitivity Speakers - Page 9 - diyAudio
Old 19th February 2013, 11:10 PM   #81
Originally Posted by tinitus View Post
is that not how it is with the biggest compression drivers ?
The BMS 4590 is a co-axial compression driver with two annular diaphragms.
On a non-beaming horn, it could have much wider HF dispersion.
Old 20th February 2013, 01:00 AM   #82
Originally Posted by weltersys View Post
That horn driver combination has only half the dispersion at 15K as at 1K.
If you consider that good dispersion, what does a bad dispersion look like ?
Hi Art, how are you doing?
OTOH, this horn has almost 90 degree dispersion at 15K. That is pretty good. To me its more that it loses its pattern control, not that it doesn't have enough HF dispersion.
Old 20th February 2013, 02:07 PM   #83
Based on discussion here, I conclude that combing filtering won't be important for highs, so a Tweeter could be added later, if there is not easy solution with the horn implementation.
What I really dislike about designing this Horn, is that all the Mids (<1khz) are performed by the Woofer.
Wondering how big the horn has to be to cut lower.
I also have seen implementations with a Bruce Edgar Mid horn.
Do you think this affects mid (vocal) quality?
What are your thoughts?
Cheers!
Carlos
Old 20th February 2013, 02:31 PM   #84
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by charly chile View Post
... so a Tweeter could be added later....
no
small tweeters does not match well with bigger mid horns
depends on the woofer type, and size ofcourse
you need a relatively big midhorn/waveguide with a cone driver
and a realtively big waveguide on top, with 1" driver
midhorn is best lifted off the floor (unless its very big and able to stand on its own)
a sub of whatever design could be convenient for that, but doesnt have to be
its really not be a matter of what might be the best
but much more about what you will be able to make work
its really pointless to suggest a design if you dont understand what it takes to make it work
Old 20th February 2013, 02:36 PM   #85
someone is selling 4 beymas 12ml100 in chile, at USA prices.
This seems to be a 12 inch driver that can reach 40hz in bass reflex enclosure !!??
Should I replace my pair of Eminence Omega Pro 18 for a pair of Beymas 12ml100?
I would like to doit if I am getting more Finesse and subtleness in the midrange.
And of course, thinking in adding a Horn on top.
If it reaches 40hz solid, sounds a good deal to me...
Old 20th February 2013, 02:38 PM   #86
thinking twice about it....I would definately suggest a very big mid waveguide and big tweeter ditto
subs are secondary add ons
edit, I had not seen your previous post before this, sorry
Old 20th February 2013, 02:45 PM   #87
you mean 12MI100 ?
no, its a big midrange only
not enough Xmax to play much bass, high Fs, very low Qts
a genuine midhorn driver
might work well in a big midhorn rolling off 100-150hz
Old 20th February 2013, 02:51 PM   #88
Thanks. Data sheet said up to 40hz in bass reflex enclosure, then I thought it could be good to blend with a horn.
Old 20th February 2013, 02:56 PM   #89
Thanks. Data sheet said up to 40hz in bass reflex enclosure....
then we are not looking at the same driver
mine say 94hz in BR
Old 20th February 2013, 02:57 PM   #90
Speakerholic
Cal Weldon's Avatar
you mean 12MI100 ?
I think he means these. ML not MI
Liquido 4 Woofers Beyma 12ml100, 450 Watts Rms (nuevos) - $ 98.750 en MercadoLibre
planet10 needs your help:
Let's help Ruth and Dave
Phase plug design for high-directivity horn Spatz Multi-Way 2 4th October 2014 06:34 PM
How do I design a back chamber for a horn speakers. djn Multi-Way 15 27th November 2010 03:40 AM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 12:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
Copyright 1999-2017 diyAudio
