#31 |
If you go to Doctor Boar; DIY loudspeakers and HiFi and scroll down to "Kuben" that is a simplified version of the La Scala. There are two things to notice.
1. Low pass frequency is way higher than predicted by 2Fr/Qes 2. You get more bass close to cutoff if you have a driver with higher Q and lower Fr. No free lunch though, sensitivity goes down and if you have to much of it there will be a peak at cut off. |
#32 | ||
A super tweeter does often not better then 40 degrees of axes. So they are the same as these E-jmlc. Then I would go for the E-jmlc 600 horn for good dispersion see sonogram. It needs a 1" driver that makes good dispersion. And very good low end for a 1" driver. XO 700Hz 4 order. ![]() Other option is a e-jmlc for 2" driver. very good dispersion also at 10kHz. would be my choice so you can cross low. ![]() Quote:
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 09:15 AM. |
#33 |
This will make filtering much easier normal second order 3 way. XO 250Hz and 1500Hz. The mid range and seos wave guide will make a very small monitor speaker and a big frontloaded horn sub.
101dB in 2pi down to -3dB 45Hz! ![]() ![]() This is great to combine with a dedicated high efficient midrange. RCF MR10N301 100dB 1Wmtr No horn no coloration RCF - MR10N301 Now you can cros at 2kHz and use a seos 10 wave guide. With a 1" B&C DE250. Or a selenium one. Look at the good dispersion. And no horn coloration.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 10:02 AM. |
#34 | |
![]() then its up to the sensitivity of a horn tweeter and for that, how about a PPSL sub with 4x 18" woofers ![]()
#35 |
Design of the box 101dB 45-20000Hz 2pi. I call it " The super la scala ".
Filter idea for sub 1 order low 100Hz Midrange 1 order high 200Hz and second order low 1000Hz High second order high 1000Hz How to hide a mega front horn. A 1,4 meter high front horn 45cmX55cm. With midrange and seos 10 wave guide. Closed volume omega18 must be reduced to 55 liter.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 10:41 AM. |
#36 |
Horn mouth to the front it will help to reach the 1,2 meter horn length easier.
![]() 1pi output of the mega sub front horn. with the first order 100hz filter it will make 106dB 1 meter! -3dB 40Hz! 102dB. That is the output box placed near backwall. With a 5W amplifier this will make a mighty 112dB at 1 meter.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 11:08 AM. |
#37 |
looks clever Helmuth, but make it twice as big(wider)
#38 |
Omega 18A sub horn placed in the corner ½ pi. With first order low filter 110dB -3dB 37Hz 1 meter. -10dB 30Hz 100dB 1Wmtr Like?
When you build the front horn like I did design, the corner placement is easy.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 11:26 AM. |
#39 |
Then it will not meet the simulation. Horn mouth 2000 square cm = 45X45 cm, it is a smart horn design with low horn coloration and very high efficiency and relative compact. And without a faulty super tweeter. Who does better? -3dB 37Hz and 110dB 1wmtr. Even the wood work will be easy witch ads to be a smart design.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 17th February 2013 at 11:40 AM. |
#40 |
and how/where will you suggest to crossover bass to mid ?
| How do I design a back chamber for a horn speakers. | djn | Multi-Way | 15 | 27th November 2010 03:40 AM |
| Phase plug design for high-directivity horn | Spatz | Multi-Way | 0 | 5th October 2010 11:54 PM |
| High Sensitivity, low cost bookshelf speakers? | jonnythan | Multi-Way | 7 | 1st March 2006 12:50 AM |
| High sensitivity(>90db) budget speakers wanted | kmj | Multi-Way | 40 | 28th April 2005 04:23 AM |
| High efficiency (HORN) vs Conventional design | mbon | Multi-Way | 13 | 8th June 2004 11:30 AM |
