Design: Horn High Sensitivity Speakers - Page 3 - diyAudio
Old 16th February 2013, 09:06 PM   #21
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Here a symulation with a closed backside it works fine probably the best solution and most compact.
2pi
1pi
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 16th February 2013, 09:17 PM   #22
Helmuth's Avatar
2pi with 35 liter backside enclosure to reach more flat response in the 2pi radiation down to 56Hz 104dB 1W meter.
I would tune the raising character down so it the sensitivity raises to lower frequencies.
So maximum spl with 5W 110dB 1meter
File Type: png Schermafbeelding 2013-02-16 om 23.14.28.png (24.2 KB, 27 views)
Old 16th February 2013, 09:34 PM   #23
Helmuth's Avatar
Better closed tuning bigger throat area.
2pi response. 104dB 1wmtr down to 52 Hz. Build your own low cost la scala with a fine quality 15 driver.
Old 16th February 2013, 11:23 PM   #24
I am very grateful for your advice. It s clear that DIYAudio was the place to look for.
I need to read all the posts more carefully, for a next round of questions. Your feed ack is so great!
1) two drivers is a good idea, means I don't need 2405, I really like that driver and wanted to have it. My question is: with only one horn going up to 18k, is it going to beam too much? When I think in horns, I think in fullness so would be disappointing to find that it only sounds good in a narrow hotspot (like my new fe126 I was testing in open baffle).
2) my woofer eminence omega 18a is good with a 400hz XO, gives big bass, moves lots of air giving a unique feeling. But I think it is very nasty with voices when approaching the mid range. Are all woofers that nasty? Or it is just beacause mine is cheap?
Will a beyma or 18sound perform more nicely in the 500hz zone where I am blending with the horn?
I will write autotech to figure out how much would be shipping for those le cleach/iwata horns.
Best!
Charly
Old 16th February 2013, 11:25 PM   #25
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
take your time
there are many ways
try search.... le cleach
Old 16th February 2013, 11:46 PM   #26
no, 18" is not just 18"
I havent heard it, but quite sure the 18" Faital 18FH500 have better midrange
and there may be others
but ofcourse big woofers with nice midrange are not many
normally a woofer with better midrange would be 15"
well, please remember I suggested a 12" in fronloaded horn down to 100hz
and a simple vented BR sub below that
not without a reason
and btw, normal average SPL could be around 96db
Old 16th February 2013, 11:55 PM   #27
ScottG is offline ScottG  United States
I'd recommend expanding your speaker's width a bit more than your 50 CM. Depth can be reduced some. A wider profile not only allows for lager wave-guides, it also provides a reduction in sound pressure loss from the baffle-step region.
This waveguide:
Fiberglass SEOS-24? DIY Sound Group
(..which is a wider dispersion design than others.)
This driver:
ND1460A - HF Neodymium Driver
The midbass really depends on the sort of volume you want for the enclosure vs. the sort of low freq. extension you want. You will want it as efficient as possible.
As Helmuth has mentioned this is a good one:
15MB606 - Very High Output MB Ferrite Driver
..but one of the Beymas may be better for your needs.
-look for drivers with low mms.
perspective is everything
Old 17th February 2013, 01:25 AM   #28
weltersys's Avatar
1) My question is: with only one horn going up to 18k, is it going to beam too much?
Charlie,
1) A conical expansion horn can have uniform dispersion to 18K.
Most good horns have polar charts so you can determine dispersion at various frequencies.
The JBL 2405 dispersion patterns are rather unusual, and not very uniform.
2) Using first order crossovers, the six dB peak the Eminence Omega 18a has around 1500 Hz would be clearly audible.
If you are using only a coil for a crossover, the peaky response might actually be worse than it looks on the graph.
There are some 18" that sound OK in the midrange, but most good two way designs use 15" cones, as an 18" beams at a lower frequency than a 15", requiring a crossover too low for a 1.75" diaphragm driver to sound good.
Old 17th February 2013, 02:09 AM   #29
I think 40hz is enough for me
Old 17th February 2013, 06:07 AM   #30
DougL is offline DougL  United States
I had some thoughts for you:
I ask about 15" woofers. Here are the responses
Looking for recomendations on 15" woofers
It looks like some of the Pro woofers are designed to play up to where their directivity matches a horn, and others will not.
If I were you, I would prototype your system with the Mini-DSp you have.
You are probably going to need a tweeter, but I would try it as a 2 way first.
I think a Mini-DIG will be your best option, with your DAC running the horn, and lesser DAC's for the Woofers and Tweeters.
As you can see, I am looking at the same things you are.
Good luck.
I will be interested in what you find.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Phase plug design for high-directivity horn Spatz Multi-Way 2 4th October 2014 06:34 PM
How do I design a back chamber for a horn speakers. djn Multi-Way 15 27th November 2010 03:40 AM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 12:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
Copyright 1999-2017 diyAudio
