Design: Horn High Sensitivity Speakers - Page 13 - diyAudio
Old 22nd February 2013, 02:39 PM   #121
Originally Posted by Helmuth View Post
Charley when you make up your design goals, then it will become automatically clear witch options will be Left.
100dB 1Wmtr
40Hz-20000Hz
1-2-3-4way?
max dimensions, height, with, deepness?
max power 10W?
steepness filter first,second or fourth order filter.
Maximum cost?
Yep, my fault.
>=100db (initially will keep Omega Pro18 Open baffle, so we can define a better woofer but wont be used yet...)
2 ways (and will add a jbl2405 later if needed).
Dimmension arround 150cm tall, 50cm deep, 50cm width. Deep is hard to change. but a nice looking horn that is a bit bigger would be ok.
Power available for mid-highs 0.7W or 2W
Power available for woofer 10W or 20W
Maximun cost: let's say a 1000 USD... but as you see, I am thinking on a progressive build so we could focus on mid-highs horn.
Best,
Old 22nd February 2013, 03:21 PM   #122
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
500 dollar per side .
a nice woofer cost 200-250 dollar.
a nice 1" HF driver 150 dollar.
a nice 2" HF driver 350 dollar.
a nice horn 100-300 dollar.
For 500 dollar you have to look for the low cost drivers and horns.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 22nd February 2013, 04:06 PM   #123
Helmuth's Avatar
Basreflex Eminence kappapro 15A 160,-
99-100dB 1wmtr
Eminence Kappa Pro-15A 15" Cast Frame Driver 290-422
Speaker Detail | Eminence Speaker
Here simulation compared to the 18sound 15mb606 about exact the same drivers for what data is concerned. The eminence will have a better price performance.
So how about this woofer Charley 140liter =120liter with stuffing. Box inside about 40cm X 45cm X 70cm.
$160,- piece. 40Hz -3dB!
$340,- left for horn and HF driver.
There are not to many real 100dB woofers most have a 100db peak at 1kHz and are sold as 100dB woofers.
Note: rear-port gain ads to the direct radiating cone response.
File Type: png Schermafbeelding 2013-02-22 om 18.01.30.png (34.1 KB, 362 views)
File Type: png Schermafbeelding 2013-02-22 om 18.04.32.png (38.5 KB, 358 views)
Old 22nd February 2013, 04:17 PM   #124
Originally Posted by charly chile View Post
Yep, my fault.
Best,
I am sorry Helmuth, I believe part is my fault, for not writing my ideas more clearly.
Let's focus on the mids with a Max. budget of 1000 usd for "drivers".
Since I am willing to build the horns if necesary. I think I can build an Iwata horn or a Tad wooden horn with my tools and skills.
So we should look for something that works from 400hz? to >15khz
I emailed Autotech, in Poland, their shipping company only can send their horns to Chile to a bussines (not to an individual person). Probably I could get a friend's bussiness to do so, but because of big size and shipping costs, I am feeling more tempted about building an Wooden Iwata like the TADs.
Old 22nd February 2013, 04:26 PM   #125
Helmuth's Avatar
Originally Posted by DaveCan View Post
What about trying a 1.4'' coaxial compression driver like the BMS on a horn mated to a good 15'' or two? Super high sens for sure
Like Dave advised I think BMS is the best way to go low with a HF driver BMS allows very low crossing of thier drivers.
It are coaxial horn drivers with crossover.
Compression Drivers
Look here see this coaxial 1,4" driver. 300-22000Hz
Curves
Old 22nd February 2013, 04:39 PM   #126
Helmuth's Avatar
And a more modern horn approach for mid high is the synergy horn. A coaxial conical-horn.
topic on this horn very good dispersion. And not exspensive. < $200,- all the drivers and mdf.
DIY Synergy horn
Red Spade Audio: Synergy horn flat pack kit
Old 22nd February 2013, 05:10 PM   #127
Helmuth's Avatar
The hole Redspade explanation of the synergy horn
DIY Synergy horn - intro Red Spade Audio: DIY Synergy horn
Synergy horn concept Red Spade Audio: Synergy horn
S1 Build pics Red Spade Audio: Synergy horn - update
S2 intro Red Spade Audio: Synergy prototype #2
S2 Build pics Red Spade Audio: Synergy prototype #2 - construction
Hornresp lessons Red Spade Audio: Synergy horn - hornresp lessons
Sims vs measurements Red Spade Audio: Synergy horn - simulations vs measurements
Directivity measurements Red Spade Audio: Synergy horn measurements
S3 intro Red Spade Audio: Coming soon: S3 - my next Synergy horn
Phase plugs Red Spade Audio: Synergy mid driver mounting and phase plugs
Old 22nd February 2013, 07:02 PM   #128
Helmuth's Avatar
Made a 4pi simulation of the eminence 6cbm. 4 drivers on a unity horn.
File Type: png Schermafbeelding 2013-02-22 om 21.01.03.png (25.3 KB, 351 views)
Old 23rd February 2013, 09:19 AM   #129
Helmuth's Avatar
improved it a bit futher.
File Type: png Schermafbeelding 2013-02-23 om 11.19.10.png (19.9 KB, 323 views)
File Type: png Schermafbeelding 2013-02-23 om 11.20.38.png (23.1 KB, 69 views)
Old 24th February 2013, 06:37 AM   #130
The mids need to be modeled as offset drivers, your schematic isn't showing that.......
Phase plug design for high-directivity horn Spatz Multi-Way 2 4th October 2014 06:34 PM
How do I design a back chamber for a horn speakers. djn Multi-Way 15 27th November 2010 03:40 AM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 12:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
Copyright 1999-2017 diyAudio
