Design: Horn High Sensitivity Speakers - Page 11 - diyAudio
Old 20th February 2013, 08:54 PM   #101
mitchba is offline mitchba  Canada
mitchba's Avatar
Originally Posted by charly chile View Post
That looks pretty sharp.
How much tube power do you have per channel?
I guess you are using only one stereo amplifier.
Thanks. Yes, one stereo amp. It is a DIY Nelson Pass A40 that I put into three chassis to look similar to the Dynaco ST-70 tube amp. It's 40 watts of Class A per channel.
Old 20th February 2013, 09:19 PM   #102
Originally Posted by Helmuth View Post
some low cost HF drivers.
BMS 4554 1,4" $202,-
Faital PRO HF144 1,4" $298,-
Eighteensound HD1480T $312,-
For BMS the 4550 1" would be a better selection than the 4554, 1.4"
The 4550 will crossover lower.
Old 20th February 2013, 09:28 PM   #103
mitchba's Avatar
I personally like the brightness of a metallic dome. IMO harness comes bad from wiring poor capacitors and wire wound resistors in the cross over.
Again do not judge to early when you not did enough crossover work. Try other capacitors metal oxide resistors and try copper wire in different gauge or tinned copper. And silver plated copper and carbon or carbon copper wire.
I had a huge tuning difference with the bi-wire set by testing different loudspeaker wires.
Hi Helmuth, I think Mr. Crites makes some pretty good xovers with Sonicaps... Or at least in my research, I have not come across anyone complaining about them.
My comment is based on the 1" Selenium D220Ti, which sounds harsh to my ears and measures higher distortion than the CP27 driver that I just put in my system and changed nothing else.
Attached are two distortion measurements with the only change being the 1" compression drivers. As mentioned, they xover at 5 kHz. There is a big rise in distortion at 6 kHz on the D220Ti compared to the CP27. It is quite audible.
Maybe I got a bad batch of 220Ti, or this is the way they are, I don't know...
I am looking forward to installing the BMS 4540ND to see what they sound like and measure.
Cheers!
Old 20th February 2013, 09:56 PM   #104
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
When they distort the cause is clear
Cheers!
I own a pair of bms 4540. They are good but in the long run I did not like them enough a bit to thin.
A popular 1" is the RCF cd350 polyester.
RCF - CD350
I had the chance to test the DE25 very nice clear sound on janzen superior-Z.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 21st February 2013, 05:24 PM   #105
I was reading more about the Cornscala design.
Have a fun club, people says have good bass performance of Klipch Cornwall, and good mid high qualities of La Scala.
It's a >100db design. My amplifier has 0.7W with 71A and 1.5W with 45 so sensitibity is very needed.
To be honest, it's a bulky design, is harder to make it look nicer.
I am thinking about starting my own project (not an identical copy) based on the general aproach of the Cornscala.
1. Use my Eminence Omega 18A Pro in a Bass reflex config. front vented.
2. Put the horns outside the enclosure, probably this reduces coupling, but in really I think it will look better and can make it modular, so will be easier to change components.
3. I will look for the tweeter later, It could be the 2405.
4. So the Job now is to define what wooden horn and what compression driver should I use.
Note1: Eminence Omega 18A pro, doesnt have 100db. And my understanding is that a BR only will give more bass extension. At the moment I will think on attenuating more the highs, until I get a better bass. But I still would like to think in options for the bass, to start planning ahead.
Note2: I have a pair of 41hz SS 20W and 100W amplifier, another option would be use that for the woofer. I m just afraid of loosing phase integrity when using two amplifiers.
Please let me know any concerns about this thinking.
Best,
Charly
Old 21st February 2013, 05:38 PM   #106
Helmuth's Avatar
acitve low is a good thing mid high is better passive imo.
Old 21st February 2013, 05:45 PM   #107
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
..... mid high is better passive imo.
but still very difficult
Old 21st February 2013, 05:49 PM   #108
Hi Tinitus,
What would be the things to check to make that work?
Best,
C.
Old 21st February 2013, 05:54 PM   #109
I would like to
but sorry, I have to say... if I could tell you like this it wouldnt be difficult
your eminence woofer/sub thing sounds ok, it will be fine, build that, no problem
and then you could try any 2way
maybe eminence Beta8 with a smaller tweeter
Old 21st February 2013, 06:02 PM   #110
I would like to
can that sound better than horns?
remember everything started with the idea of having CDs and Horns.
Phase plug design for high-directivity horn Spatz Multi-Way 2 4th October 2014 06:34 PM
How do I design a back chamber for a horn speakers. djn Multi-Way 15 27th November 2010 03:40 AM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 12:50 AM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
Copyright 1999-2017 diyAudio
