Old 20th February 2013, 05:31 AM   #51
OllBoll is offline OllBoll  Sweden
Originally Posted by PeteMcK View Post
re: "Isn't exactly the opposite what you should be doing since the crossover points are mostly determined by the limitations of the chosen drivers? " - if the crossover is implemented properly, it doesn't matter where the xover freq is, anything else is mere shadow chasing
Yes, if and only if the driver can play that low / high. Say for example you have a two-way with an 6.5 inch driver and a dome tweeter and you aim for the standard wide dispersion design. In that case you need to cross at ~ 1600-2400 since the 6.5 inch drivers dispersion drops at this point.
The idea that the crossover points is independent from the drivers would be true, however, if we had ideal drivers with good dispersion over the whole frequency range but then why not use that driver full range and skip the crossover?
Old 20th February 2013, 06:08 AM   #52
puppet is offline puppet  United States
I think what Pete is saying is that if the drivers dictate a range of "x" hz to "x" hz to perform their best (all things/compromises considered) then just put it there.
"Properly implemented" ... you won't be able to tell where it is exactly.
Old 20th February 2013, 02:09 PM   #53
AllenB is offline AllenB  Australia
Originally Posted by wintermute View Post
if it is implemented properly it shouldn't matter
There is arguably a degree of truth to this. An exception would be where the system design dictates a certain crossover point, eg: where it is based on a frequency dependent acoustic behaviour of the drivers.
Much can be found in the polars.
Old 20th February 2013, 03:39 PM   #54
True ... but I was referring to beer in hand listening.
Old 20th February 2013, 10:43 PM   #55
tvrgeek is offline tvrgeek  United States
Well, there is a large camp that suggests the crossovers in the critical audible range of voice, 2K to 4K, is not as pleasant sounding as if the crossovers, provided drivers within their limitations, out of that range would be. I have built speakers with crossovers right smack in the middle and they are very good. Would they be better with a midrange? Only another build will tell.
Numerical Solving Techniques for Optimum Crossover Design thadman Multi-Way 5 21st May 2009 05:29 AM
Optimum frequency response curves in the bass range The golden mean Subwoofers 8 30th June 2008 05:22 PM
Crossover Frequency Ironhead Multi-Way 14 17th June 2008 09:12 PM
crossover frequency Laufer Multi-Way 2 22nd October 2003 06:52 PM
crossover frequency ray Multi-Way 1 10th September 2001 06:31 AM
Copyright ©1999-2013 diyAudio
