#71 | |
Like you, I have been around through the introduction and refinement, and abandonment of the pinched throat horns as they made their way around Altec, EV and JBL, and owned quite a few of the latter two back in the 1980s. Each horn type has positive and negative aspects that must be weighed against each other for the desired application. I would not advise the use of the Paraline for home use, the negative aspects outweigh the positive. Any technical issues inherent in the Synergy design approach are far outweighed by the many technical issues it solves. The simplicity of construction, saving in real estate, reduced midrange distortion, even dispersion, and single point source radiation pattern in my opinion make it a winner for the mid/high portion of what Steve is attempting. Steve will hopefully make up his own opinion after making a listening comparison between horn types. Art |
#72 |
Art,
On your last post I am in complete agreement with you. I see no good coming from trying to use the Paraline in a home environment for high end sound applications. I understand your position on the Synergy design for large format PA use. |
#73 | |
Obviously, the driver count, amplification power needed for the desired SPL, and dispersion patterns can all be adjusted for home use. As the requirements for surround speakers are different than left/center/right, I would not likely be using the same dispersion pattern for the side and rear, but that is yet another "design issue" for Steve to consider. Art |
#74 | |
Anyway I might be buying a hand full of Altec A6's. At the very least they should keep things moving with the theater build and buy me time to study the synergy horn without holding things up. |
#76 |
#77 |
The 1505s are my favorites. Alas - too rich for my blood. I run the more humble 1005, which isn't bad for a small room. I also own 803s, which are nice, but not as nice as the 1005s.
The only cons I find is that it's hard to get the big multis to play high, ~7-8Khz is tops. But that may be driver dependent. I remember with Westrex drivers on the 1505, I really didn't feel the need for tweeters. They did add some "air" but I usually found it artificial sounding. I'm a fan of the multicell. I just don't know another type of horn that gives me such a realistic sounding space and timber. Some folks don't like them, but I suspect much of that is on a theoretical basis, not from listening to them in a well implemented system.
Take the Speaker Voltage Test! |
| HOLMImpulse measurements into polars? | boris81 | Multi-Way | 3 | 26th July 2011 09:27 PM |
| Multicells horn with BMS | hugobors | Multi-Way | 10 | 18th September 2010 08:05 AM |
| Altec 811B horns and Altec 414z 12" Speakers | xecluded | Swap Meet | 0 | 21st September 2008 05:21 AM |
| Boutique Bi-polars? | setmenu | Parts | 2 | 26th December 2005 04:19 AM |
| waterfall plots | bonsai171 | Multi-Way | 21 | 10th August 2004 12:29 PM |
