I am putting together a cabinet containing a 15inch 300W bass driver and a horn. I think the crossover frequency should be 3KHz. I have seen some Piezo horns with the boast that, since they are high impeadance, you dont need a crossover network.
.......................but what happens to the HF that hits the bass driver? How much power can a "high impeadance horn output? How could I balance the output? What would the effective total impeadance of the cabinet be? |
#2 |
Hi
First i will try to convince you not to use a Piezo Horn. They may be cheap, but will never really provide a useful sound quality or sound pressure level. Even if you should go ahead and use a Pieze, the use of a crossover is still recommended. The Piezo crystal can only take so much power from the Bass and at high power levels the horn is likely to burn. Use a low cost dynamic horn instead, and 18dB of filtering for the horn. 3kHz is ok. It will sound much better and louder (which i suspect this speaker is mainly intended for) For the Bass you should definitely also use a crossover to avoid high frequencies out of the bass units operating area, being passed on distorted by the driver. Use 18dB of filtering as well. The total impedance of the box is still 8 Ohms if the drivers are, because they are only loading the amplifier in their specific frequency area. If you need to calculate the parts required for this filter, go here: http://www.lcaudio.dk/com/passivexover.htm |
#3 | |||||
But you will need a xover. Quote:
#4 | ||
Generally, a 12" driver conservative upper limit before beaming is around 863 hz - maximum upper limit due to beaming is twice that. you also want to try to crossover at the point that the dispersion characteristics of the woofer match or blend with those of the horn. regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#5 |
anyways...I think piezo sucks...they are only used for low priced stuff...gives an annoying sharp sound and generally lousy sound...there might be certain exceptions...I dun noe of any right now...sa for the crossovers...try the calculator link on top...it works quite well...or go for a Bi-Amped system.
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#6 |
eeeeek! Kinda what I expected really. What I didn't mention is that these will be 4ohm cabs so the horn needs to be 4ohm also (don't they?). (i'm thinking about hi/low balance)
Since I can't find a 4ohm horn what about 2 X 8ohm ones in parrallel, positioned next to each other? Would the HF sound waves clash? |
#7 | |
You won't need 2 horns, they will interfere acoustically, and a resistor is about $2. |
#8 |
Here's where my plan falls over........
I was planning on using the Emenence Delta15 which has an SPL of 101db with the peak up arround 2-4Khz ( so why crossover at less?) . Unfortunately, they only make an 8ohm version MaKenzie make a 4 ohm unit but the ave SPL is only 98db. ![]() So I can either push 140w in to an efficient driver, or push 200W in to speakers that run 3db less efficiently. Same output Anyone know of an efficient 4ohm driver? |
#9 |
frugal-phile(tm)
Piezo's need an XO to sound decent -- 22 ohm shunt + suitable cap in series -- are suited for use above 7K or so only (ie PHY-HP K30). A piezo isn't efficient enuff to keep u with either of your woofs which, as Brett says, won't go hi enuff -- when i was doing PA i set the 15s to XO at 300 -350 Hz.
I wouldn't sweat the 4 ohm/8ohm thing. The more efficient driver will still play louder, your amp will be less stressed and typically produce less distortion. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | |
another dave |
| Tangbang and other high sensitivity tweeters | nickmckinney | Multi-Way | 0 | 15th May 2008 09:06 PM |
| Small but high quality tweeters? | Tenson | Multi-Way | 3 | 22nd January 2007 03:55 PM |
| High Pitch Noise in tweeters | bigrubes24 | Car Audio | 2 | 28th April 2005 12:39 AM |
| high frequencie tweeters 50khz | priscared | Everything Else | 23 | 11th February 2004 01:31 AM |
| Page generated in 0.11213 seconds (81.84% PHP - 18.16% MySQL) with 10 queries |
