Open-Baffle Subs – “Subwoofer Origami” - Page 3 - diyAudio
Old 15th February 2013, 10:28 PM   #21
Banned
Originally Posted by john k... View Post
Curious, what was the measurement distance?
About 40cm (16").
Old 16th February 2013, 01:23 PM   #22
gainphile's Avatar
[QUOTE=markus76;3369563]Yes. You can't pack two 12" woofers any smaller.
Surely the output of such topology is Dipole??
http://gainphile.blogspot.com
Old 16th February 2013, 01:30 PM   #23
Banned
Red = front chamber
Blue = back chamber
Gray = side
Mic was placed 10cm from enclosure.
Old 16th February 2013, 09:40 PM   #24
gainphile's Avatar
So it is a dipole from that measurement
Old 17th February 2013, 03:14 AM   #25
puppet is offline puppet  United States
markus76 .... back chamber(s) resonance around 180hz ... front around 320hz ... is that about right?
Old 17th February 2013, 07:29 AM   #26
Banned
Yes. A little bit less output at the back.
Old 17th February 2013, 07:34 AM   #27
Banned
Chamber resonanz is about 270Hz. Here's the impedance:
Note how the driver resonance decreased from 31Hz to 21Hz.
Old 19th February 2013, 05:02 AM   #28
Face is offline Face  United States
Face's Avatar
Not as pretty as the one above due to only being a test box. Drivers are JBL GT5-15: GT5-15 | 15? single voice coil subwoofer | JBL US
Except at the extreme LFs, distortion is only ok...(taken at 1M).
On axis.
90 deg.
180 deg.
Only looks usable up to 100-125hz, which should be fine as the mid I have in mind is an AE TD-15M.
What intrigues me is the spider venting is exposed on the outside. I may cover it with another layer of ply on the outside just to see what happens to the response. It may help with LF extension, but it also may make the dipole peak worse, no?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 20th February 2013, 11:11 PM   #29
Face's Avatar
No love for my ghetto box?
Old 20th February 2013, 11:16 PM   #30
gainphile's Avatar
The issue I see with that (and other 'slot loaded') is the difference between front and rear output.
If you notch the front output quarterwave, what happens to the back output ?
If smooth dipole radiation is desired then the front and back output needs to be as symmetrical as possible.
First Open Baffle project. EV LT-12 Wolverine's w/ t-35 tweeters and sub helper subs jonirvine Multi-Way 0 27th January 2012 04:57 AM
Lab 15 subs on open baffle? Racket Scientist Full Range 3 24th August 2010 06:12 PM
Office desk as open baffle subwoofer Franz Gysi Subwoofers 8 29th June 2009 07:13 PM
Open baffle subs and Maggies Luke G Planars & Exotics 10 3rd February 2008 04:55 AM
For Full Range With Subs -- Sealed Box Vs Open Baffle ? DrDeville Full Range 4 21st January 2007 06:26 PM
Copyright ©1999-2017 diyAudio
