#11 |
#12 |
Markus
How is the low end, vs other 12 inch * 2 dipoles? |
#13 |
Markus |
#14 |
Well, there IS a low end
This is with a 9dB boost at 24Hz and a 24dB high pass at 20Hz:![]() This is unsmoothed data and 1Hz frequency resolution
Markus |
#15 |
Nice - what are the woofers
#16 |
In which configuration, dipole or Ripole? The dipole is described at
Visaton ws25e-8 and H-frame I promised Axel Ridtahler (inventor of the patented Ripole) not to disclose details about my construction. You would need to contact him directly at axel.ridtahler [at] kit.edu
Markus |
#17 | |
thanks |
#18 |
The frequency plot shows the Ripole. Didn't measure max. SPL for the H-frames.
Markus |
#19 |
This FR is impressive, but remember SPL and low frequency response will be generated by cone area, cone movement and cone resonance. Now nothing is disclosed about the speaker units, so SPL dB is not known and 12" as judged what markus said himself is probably a SLS12 from Peerless. By itself it won't play excessivly high in a Ripole. But be a superb SUB. As Ripoles in fact are exellent OB SUBs with the right speakers.
/Erling Last edited by skorpion; 15th February 2013 at 07:29 PM. |
#20 |
Curious, what was the measurement distance?
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
| First Open Baffle project. EV LT-12 Wolverine's w/ t-35 tweeters and sub helper subs | jonirvine | Multi-Way | 0 | 27th January 2012 03:57 AM |
| Lab 15 subs on open baffle? | Racket Scientist | Full Range | 3 | 24th August 2010 05:12 PM |
| Office desk as open baffle subwoofer | Franz Gysi | Subwoofers | 8 | 29th June 2009 06:13 PM |
| Open baffle subs and Maggies | Luke G | Planars & Exotics | 10 | 3rd February 2008 03:55 AM |
| For Full Range With Subs -- Sealed Box Vs Open Baffle ? | DrDeville | Full Range | 4 | 21st January 2007 05:26 PM |
