Old 21st February 2013, 02:16 AM   #31
Brendon is offline Brendon  Canada
Originally Posted by markus76 View Post
About 40cm (16").
Hi Markus,
What's your subjective opinion of your Ripole versus H-frame, for your particular setup?
Thanks!
Brendon
Old 21st February 2013, 08:04 AM   #32
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Hi Markus,
one more question, I've read somewhere that you delay your subs.. Did you try using them without delay? Can you tell the difference? Will I be good without delay?
thanks!
Old 21st February 2013, 08:18 AM   #33
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by gainphile View Post
The issue I see with that (and other 'slot loaded') is the difference between front and rear output.
If you compare a "ripole" with Nelson Pass' "SLOB", it is evident where the symmetry is - and where not.
If you notch the front output quarterwave, what happens to the back output ?
In a ripole you have the same notch/quarterwave situation in front and back. After all the cone can't move in different ways on its front and back side.
If smooth dipole radiation is desired then the front and back output needs to be as symmetrical as possible.
What is wrong with a subwoofer construction if the radiation pattern tends a little bit to cardioid?
www.dipolplus.de
Old 21st February 2013, 09:04 AM   #34
markus76 is offline markus76  Germany
Banned
Originally Posted by Brendon View Post
Hi Markus,
Thanks!
Brendon
Not sure what you're asking.
Old 21st February 2013, 09:06 AM   #35
Banned
Originally Posted by sumacSK View Post
Hi Markus,
thanks!
Never tried using them without delay.
Old 21st February 2013, 09:10 AM   #36
Banned
There is no dipole radiation at low frequencies within an acoustically small room.
Here a dipole essentially behaves like two monopoles with one monopole inverted.
Old 21st February 2013, 09:18 AM   #37
Banned
Originally Posted by Face View Post
No love for my ghetto box?
Not sure if this driver is qualified for Ripole use (parameters, vent hole). Did you get in contact with Axel Ridtahler? He can probably tell you right away if the driver works in a Ripole.
Old 22nd February 2013, 03:26 AM   #38
Hi Markus,
Which of your Ripole or H-frame do you prefer?
Thanks,
B
Old 22nd February 2013, 05:58 AM   #39
Banned
Hi Markus,
Thanks,
B
The H-frame configuration uses two 10" drivers whereas the Ripole uses four 12" drivers. This is 3 times the diaphragm size hence I prefer the Ripole for better power handling capabilities and lower cutoff frequency.
First Open Baffle project. EV LT-12 Wolverine's w/ t-35 tweeters and sub helper subs jonirvine Multi-Way 0 27th January 2012 03:57 AM
Lab 15 subs on open baffle? Racket Scientist Full Range 3 24th August 2010 05:12 PM
Office desk as open baffle subwoofer Franz Gysi Subwoofers 8 29th June 2009 06:13 PM
Open baffle subs and Maggies Luke G Planars & Exotics 10 3rd February 2008 03:55 AM
For Full Range With Subs -- Sealed Box Vs Open Baffle ? DrDeville Full Range 4 21st January 2007 05:26 PM
Copyright ©1999-2017 diyAudio
