Design me a crossover and I'll build it
Old 15th February 2013, 01:24 AM   #11
454Casull is offline 454Casull  Canada
I will need a fairly significant amount of BSC. Where it's going, it will almost be like a L-R main.
Pic attached. I will mount it right underneath the PS3, above the receiver.
Old 15th February 2013, 01:30 AM   #12
Jay1111 is offline Jay1111  United States
It is getting full bsc, the bass roll off will work for an 80hz sub xover.
Old 15th February 2013, 01:37 AM   #13
Also, I hope it's not too late to say this now, but the ears will be about 18" above the tweeter. The required spread is +/- 22 degrees.
Old 15th February 2013, 01:44 AM   #14
Vertical will be fine still, but you could always tilt the speaker a few degrees up if needed. Horizontal is extremely good out to 30 degrees, and still very good past that.
Old 15th February 2013, 03:07 AM   #15
I didn't see your image before, but yes you should tilt the speaker up at least 5 degrees. The mid needs 4 liters sealed, the woofers each need 10 liters with a 2" x 6.5" port for each woofer.
I like how this thread has a 1 star rating. Sorry for simulating a design for this guy
(I didnt see any iron core inductors on Solen, but you if you find an 18ga iron core I would use that on the woofer for a much cheaper solution)
Old 15th February 2013, 03:09 AM   #16
dumptruck is offline dumptruck  United States
As the only other person that posted anything in it, I feel compelled to let you know it wasn't me . I never even remember ratings exist.
Old 15th February 2013, 01:52 PM   #17
Wasn't me that posted the rating either... Thank you very much for your assistance.
What happens if I leave the box sealed instead of porting it?
Can you describe the slopes or any details you feel are particularly important?
Old 15th February 2013, 02:21 PM   #18
Acoustic slopes are: Woofer 2nd order LR, The mid HP is also 2nd order LR. The mid LP is 4th order LR, and the tweeter's also 4th order LR. Crossover points are 470 hz and 3700 hz. The Fountek is going to be the shining star, covering everything important.
You can try sealed, but I wouldnt advise it. There will be an impedance peak from the woofers right where the inductor is also causing a peak, which might lead to a boomy sound. You would only need 2" clearance behind the speaker for the 2" port to function properly. You could also drop down to four 1" x 7" ports for each woofer, then you would only need 1" clearance behind the speaker.
Old 15th February 2013, 02:54 PM   #19
How did you get the frequency and impedance plots for these drivers? From Zaph or the manufacturer? Or does PCD have a database of such things already?
Old 15th February 2013, 04:16 PM   #20
Mid and tweet are from zaph, woofer from manufacturer.
Design me a crossover and I'll build itHide this!Advertise here!
can someone help build me a passive crossover design? illnastyimpreza Multi-Way 14 16th March 2011 09:17 PM
Marchand Crossover Build Help Beez Analog Line Level 2 14th November 2009 05:52 PM
Build your own Virtual Crossover Netlist Multi-Way 0 2nd January 2007 10:22 AM
What should I use to build my own crossover? punkrokr1701 Parts 12 7th September 2006 03:18 AM
please help me build my crossover skylar112 Multi-Way 4 29th June 2006 11:40 PM
Copyright ©1999-2017 diyAudio
