I added these parameters to WinISD, is this correct? - Page 2 - diyAudio
Old 15th February 2013, 08:32 PM   #11
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Hi that should be fine. You can always modify the cabinet foam and wading by removing the bass driver.
The more foam and wadding you have the more sound will be absorbed so if you find the cabinet sounds "honky" you can add some more. Also since the speed of sound in foam and wadding is slower then in air it also slightly increases the apparent size of the box as it takes longer for the sound wave to hit the sides of the box so you can make minor tuning modifications ths way.
Andrew
TS parameters and added series coil jamikl Multi-Way 6 3rd June 2011 05:42 AM
AE TD series parameters - which is correct...? Defo Multi-Way 3 6th July 2009 11:55 PM
WinISD - Vent Mach Calc Correct? BlueWizard Multi-Way 7 3rd August 2008 11:02 PM
TS parameters. who's correct??? dallaire Multi-Way 6 16th December 2007 08:03 PM
Is WinISD correct? mazeroth Multi-Way 9 2nd November 2004 02:40 PM
Copyright 1999-2017 diyAudio
