RS3000 Crossover Network with 8 ohm driver
Old 13th February 2013, 03:07 AM   #1
leosep is offline leosep  ominican Republic
Default RS3000 Crossover Network with 8 ohm driver
Can i use a infinity RS3000 Crossover Network with a 8 ohm driver? I think that the RS3000 is 6 ohms.
Old 13th February 2013, 03:23 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
the woofer must be 4 Ω and the tweeter 8Ω , thus giving a 'nominal' 6Ω
impedance . So if you are using an 8Ω woofer you should double the value of the lowpass inductor to get the same crossover point.
Old 13th February 2013, 04:11 AM   #3
Oh thanks for your response, but lets say that i already have the 8 ohm woofer and tweeter and the 6 ohm crossovers.
Old 13th February 2013, 04:24 AM   #4
The 6 Ω value is given by the manifacturer for convention: it tells you and awares you that it's not a 8Ω speaker nor a 4 Ω one. You can consider the 6Ω as the average impedance of the whole speaker, being composed by a 4Ω woofer and a 8Ω tweeter; the value of the lowpass inductor is calculated for the 4 Ω woofer ; the highpass net is calculated for the 8Ω tweeter .
Using an 8Ω woofer with that inductor would shift the crossover frequency higher
Old 13th February 2013, 06:26 AM   #5
system7 is offline system7  United Kingdom
system7's Avatar
Such a vague question does have a vague answer, as picowallspeaker is saying.
Let's be more definite. Presumably your original 4 ohm polycone woofers have rotted foam surrounds. You have some (unspecified) 8 ohm units to replace them.
This needs a bigger bass coil for sure. You will also need to increase the input resistor to the tweeter filter to reduce its level to match.
Something like 1mH, 10uF and 1 ohm on the bass filter. Try around 6 ohms wirewound on the treble filter input to match levels. Shouldn't be too bad.
I would reckon these speakers need to be mounted close to a wall. Not much bafflestep there. The 10uF value might need some tweaking smaller down to 6.8uF. Hard to say, because it depends on the woofer, but I'd start with 10uF.
Best Regards from Steve in Portsmouth, UK.
Old 13th February 2013, 06:35 AM   #6
I owned a pair of RS5000 ( sheesh! They were outrageously expensive at the time ) and when the foam started to rotten...well, I think my DIY adventure started from there
Old 13th February 2013, 06:48 AM   #7
system7's Avatar
I notice there are a lot of refoam kits for these speakers. That might be an option.
Just for interest I simmed a speaker with 4 and 8 ohm W170 paper drivers to see how the crossover changed in Visaton Boxsim.
Make of it what you will, because polycones are different animals, but results below:
Old 13th February 2013, 02:43 PM   #8
Default What about this one
Hi all, thank you so much for your responses, im new to this and im trying to understand what im doing hehe. And what about this crossover with this tweeter and woofer, specs attached:
Tweeter
2 7/8" acoustic dome tweeters
Rating 50 watts RMS / 100 watts peak
SPL: 96dB @ 1W/1M
Frequency response: 1.4-24KHz
I think is 8 ohms
Woofer
Rubber surround
1" voice coil
15.6oz. magnet
Specifications:: Power Capacity: 50W/100W RMS/peak
Sensitivity: 87dB (W/M)
Impedance: 8ohm
Re: 6.7ohm
Le: 0.59mH
Frequency response: 55Hz~17KHz
Fs: 55Hz
Qts: 0.40
Qes: 0.51
Qms: 1.87
Vas: 10.04 (liters)
Xmax: 2.0mm
Dimensions:Overall frame diameter: 5.14"
Required cutout: 4.21"
Mounting depth: 2.52"
Old 14th February 2013, 01:58 PM   #9
anyone?
Old 14th February 2013, 02:16 PM   #10
Find a cheap 4Ω woofer and stick it there !
Possibly before the choice try some
What about the tweeter ? if the crossover is set for an 8Ω tweeter, find a suitable one.
make it be 3 dB louder than the woofer, but limit the choice to medium or low sensitivity tweeters .
RS3000 Crossover Network with 8 ohm driverHide this!Advertise here!
Infinity RS3000 XO change up j.leger Multi-Way 3 17th November 2012 01:38 AM
PA 100 voltage input if its 4 ohm driver / 8 ohm driver rhythmsandy Chip Amps 3 16th August 2012 11:41 AM
Crossover for 8 ohm and 4 ohm speakers mcg123 Multi-Way 12 5th November 2011 06:20 PM
what effect does a 4 driver have on an 8 ohm crossover? 60ndown Multi-Way 30 5th June 2011 07:22 PM
Putting an 8 ohm L-Pad for 6-ohm driver? nobb Parts 0 3rd June 2007 07:20 PM
