Noob needing advice - Driver cost vs Sound Quality Estimates
Old 19th February 2013, 05:15 PM   #41
jReave is offline jReave  Canada
No argument that passive xo's can get quite expensive if you choose to go with those big name parts. And if the parts count starts getting out of hand too.
However, to suggest that something like the .4ohms resistance of a single coil in a woofer circuit is going to result in such massive insertion losses that a much more powerful amp is required is a bit of an exaggeration, don't you think?
Perhaps what would be helpful is a comparison of the costing of the actual active components that will be necessary for the OP intended application vs those in a passive xo. For the latter of course, we'll have to wait until a complete simulation is completed before that can be done. I'm not sure if that is also the case for an active set-up.
Old 19th February 2013, 05:26 PM   #42
mstang1988 is offline mstang1988  United States
I've been looking at the hypex amps for an active system. The look awesome but I wish the availability in the US was a bit easier.
I'm still doing a lot of reading on speaker design. I really liked the combo previously posted and the price wasn't bad. Newtronics Temperance III. I really wish I had a chance to listen first though; anybody had any experience with them directly? The other concern I started having was thinking about a matching center channel as they are dual purpose (more music the movies though) and designing a matching unit.
Old 19th February 2013, 06:03 PM   #43
mstang, if you seriously have a budget of a $3000 for the front pair, want to re-create or surpass the S8's, if you have the woodworking skills and facilities required and wish to possibly extend the design to front and rear channels, then I think you'd be making a mistake going for something like the Temperance.
I have no doubt that's probably a good sounding speaker, but knowing Paradigm's reputation and the fact that the S8's are their top-of-the-line speakers, I don't think it will come that close to beating it for SQ. (could be wrong of course) Something like the Elsinores (Elsinore Speakers DIY ) would probably come a lot closer (altho I find them to have about 0 aesthetic appeal) but with your budget and starting from scratch, I think you can still do better than that. And I think you could probably do this with either active or passive xo's depending on which way you want to go.
Give me a little time - I am researching some potential drivers that will work within your desired configuration and that should equal or surpass your objectives while still staying within your budget. My thinking is that for $3000, you should actually be able to come up with a set of jaw droppingly-good speakers.
And it's the drivers that are going to make all the difference in terms of achieving your goals. Just take the S8's beryllium tweeter for example. That's one hot tweeter material these days and you can be sure that Paradigm has implemented it well. You should be looking at a *very* good tweeter for your design if you want to be thinking of close to the same results.
Old 19th February 2013, 06:44 PM   #44
Charles Darwin is offline Charles Darwin  United Kingdom
Lets just look at the impedances without DCR of the series inductor in a simple
12dB L-R passive crossover crossing at 2000Hz using 8Ohm drivers:
The textbook series inductor value for the low pass is 1.27mH
Impedance at 1500Hz is 11.96 Ohm, at 1000Hz it is 7.98 Ohm, at 500Hz it is 3.98 Ohm, at 250Hz it is 2 Ohm and at 125Hz it is 1 Ohm.
DC resistance has got to be added to these values.
The impedance of the textbook 4.98microF series capacitor for the high pass is 12.78 Ohm at 2500Hz, 7.98 Ohm at 4000Hz, 3.99 Ohm at 8000Hz and 2 Ohm at 16000Hz.
Old 19th February 2013, 07:10 PM   #45
Sorry, but I'm still not sure how this is germane to the OP?
He's got 2 x 500W monoblocks to power his proposed mains. Are you saying that if he uses passive xo's that he won't have enough power for perhaps an 88-90dB speaker?
To reach say 100dB SPL's?
Old 19th February 2013, 07:37 PM   #46
It is germane to your post in which you said that the insertion loss of a passive crossover equals the inductors DCR and no more which does seem incorrect.
Old 19th February 2013, 07:46 PM   #47
dumptruck is offline dumptruck  United States
But you just listed a bunch of impedance numbers that indicate a filter being a filter. That's not insertion loss, it's filtering. Insertion loss is negligible except in speakers with a TON of additive DCR in the crossover. What requires bigger/better amps is high electrical phase angle, which depends on the crossover design.
Old 20th February 2013, 10:42 AM   #48
3 octaves below and above crossover point?
Old 20th February 2013, 07:45 PM   #49
Yes, three octaves but the numbers you listed only happen when you put the inductor in a circuit by itself. When you add the 8Ω load that you described, it's a different story. The impedance of the idealized 1.27mH / 4.98uF / 8Ω resistive 2nd order system you suggested is attached, and it corresponds to the filter exactly. No insertion loss until you start adding DCR / ESR.
Old 21st February 2013, 07:33 PM   #50
OK, back to trying to get your speakers built. (Warning: long posts ahead)
First, understand that instead of going active, you can actually get some help from the experts in the on-line community to model your design and produce a specific passive xo for your intended application (see this current thread for eg http://www.diyaudio.com/forums/multi...ill-build.html ). If the xo is designed properly, you can still make small mid and/or tweeter level adjustments by ear or with free on-line test tones and a cheap SPL meter once the speakers are in your own environment.
Note that one little thing that might help you succeed at this is locating a fellow diyer in your area with measurement gear that would be willing to measure your speakers once the cabinets with drivers are built but without any xos designed yet. This will add an extra degree of accuracy to your project, although the simulation process is actually quite good and can produce outstanding results.
To increase the probability of achieving this, I would suggest expanding the number of people you have access to by also starting a similar thread on a second forum, Tech Talk Forum
And full disclosure, Ive been at this for a number of years but Im still far from being an expert. I can help you along the way but Ill still be relying as well on some help and confirmation from others.
OK, I wanted to answer the last question from your original post first.
Re the RTi6s, just pick a suitable 2-way project with an F3 in the 50Hz range from any of the following sites and that meets the budget, pretty much all of them have very good SQ:
Perhaps the Overnight Sensations, or the Hitmakers? https://sites.google.com/site/undefinition/diy
Veepers would be an excellent choice. Build Gallery
This one is also highly praised. Continuum, Pr
Zaph|Audio
Btw, if you havent found Zaphs site yet, bookmark it and start reading, especially if you want to shed some light on how to select drivers when youre unable to hear them first.
Cheers
jR
Noob needing advice - Driver cost vs Sound Quality EstimatesHide this!Advertise here!
Noob/Neo needing sound advice... kutnupe8 Multi-Way 3 10th September 2011 02:25 PM
Noob needing help. icor1031 Subwoofers 43 26th March 2011 01:41 AM
Noob needing sub for gigs. mrbobian Subwoofers 20 7th May 2008 10:57 AM
Advice on highest quality full range driver deandob Full Range 39 13th December 2005 02:45 PM
Noob - Needing help deciding what Gainclone design to use tsnyder41 Chip Amps 5 20th May 2003 12:54 AM
Copyright ©1999-2017 diyAudio
