Noob needing advice - Driver cost vs Sound Quality Estimates
Old 15th February 2013, 03:50 PM   #31
dumptruck is offline dumptruck  United States
Originally Posted by dublin78 View Post
Frankly, if you choose to go down the active dsp route, then you can design you own speaker with any drivers you want, in any configuration you want, and be confident of getting the result that you are looking for. So long as drivers are given suitably sized chambers, it would be hard to go wrong.
That's a bit of an exaggeration, don't you think? You want to be starting from something where the drivers all have good performance and sufficient maximum output in bands that will work reasonably well with the dispersion and baffle spacing of each driver. No fixing any of that with DSP. The main thing DSP gets you (short of fancy FIR experiments and that sort of thing) is free crossover revisions, and access to filters that are only practical at line level. That's a huge plus, but not a panacea.
Old 15th February 2013, 04:08 PM   #32
dublin78 is offline dublin78  United Kingdom
A bit of an exageration, I suppose. I was assuming that the designer was not retarded.
Regards.
Michael
Old 15th February 2013, 11:51 PM   #33
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Charles Darwin View Post
Is there a big (or even just meaningful) difference between the MDT30 and its 'replacement' CAT 308?
No experience with CAT308 .......
Old 15th February 2013, 11:53 PM   #34
Sin Bin
I have yet to hear an active speaker worthwhile , so yes a big stretch , seeing no one has gotten it right yet ...
Old 16th February 2013, 07:35 PM   #35
tvrgeek is offline tvrgeek  United States
See my post on testing the wrong way as it relates to driver cost and results. Simple, but a view.
On active speakers, could it be at an active speaker of sufficient quality just won't package well? I mean, try to put a serious quality amp in a 17L monitor speaker.
Old 16th February 2013, 07:39 PM   #36
Charles Darwin is offline Charles Darwin  United Kingdom
There is no reason to assume that with an active speaker drivers and amps have to share an enclosure.
Old 18th February 2013, 06:01 PM   #37
mstang1988 is offline mstang1988  United States
I love the discussions guys! Keep it up!
Old 18th February 2013, 09:38 PM   #38
I on the other hand have yet to come across a worthwhile passive speaker or one that could not be improved by running active.
Dynaudio does or at least used to sell the BM5 active or passive.
In a direct comparison the passive was very much inferior to my ears.
Others had the same experience with otherwise identical ATCs but they were a bit beyond my price range.
Old 18th February 2013, 11:45 PM   #39
jReave is offline jReave  Canada
Well, everything is a compromise isn't it?
If you have to spend more money on new amps of a quality equal to what you already own for each 'way' in your speaker, plus the active components themselves, then that means you have *less* money to spend for better quality drivers.
So, higher quality drivers with passive xo's or poorer quality drivers with active xo's?
Personally, I would think that if the OP found the S8's to be very much to his liking with passive xo's, then building a similar diy system with much better drivers but still with passive xo's will be more than satisfactory. And simpler too.
Old 19th February 2013, 10:45 AM   #40
The cost of high-quality passive crossover components is far from trivial.
If you are prepared to buy s/h or able to build your own amps the difference in cost is not that great at all when using the same drivers.
There is also an inevitable insertion loss with passive crossovers so to reach the same SPL levels a passive design will need a much bigger amp than an active design.
Noob needing advice - Driver cost vs Sound Quality EstimatesHide this!Advertise here!
Noob/Neo needing sound advice... kutnupe8 Multi-Way 3 10th September 2011 01:25 PM
Noob needing help. icor1031 Subwoofers 43 26th March 2011 12:41 AM
Noob needing sub for gigs. mrbobian Subwoofers 20 7th May 2008 09:57 AM
Advice on highest quality full range driver deandob Full Range 39 13th December 2005 01:45 PM
Noob - Needing help deciding what Gainclone design to use tsnyder41 Chip Amps 5 19th May 2003 11:54 PM
Copyright ©1999-2017 diyAudio
