Could I use solid wood like walnut to construct my cabinet?
Old 13th February 2013, 05:56 PM   #21
The golden mean is offline The golden mean  Sweden
Let the wood dry for a long time and treat both sides equally with oil, varnish etc. The risk is small in my opinion to use solid wood as long as the speakers are not exposed to extreme conditions (no PA usage).
(The granite on top is only used for mass-loading, there´s some on the inside as well).
Without wonderment,no life.
Old 13th February 2013, 06:17 PM   #22
Charles Darwin is offline Charles Darwin  United Kingdom
Nice driver!
Which one is it?
(the woofer, not the other.)
Old 13th February 2013, 07:34 PM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Driver is a Volt.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th February 2013, 09:06 PM   #24
Yes. Volt RV 3143.
http://www.audio-components.co.uk/pd...cts/RV3143.pdf
Volt RV3143 Radial Bass Unit
Old 13th February 2013, 10:26 PM   #25
petefrontiers is offline petefrontiers  Canada
Originally Posted by evanc View Post
You need to think about expansion and contraction. Wood grows across the grain when the humidity goes up, and shrinks back when the air is drier. You can't stop it. Try this.... solid wood sides top and bottom with the grain going around the box. Then use plywood or MDF for the front and back. This avoids grain conflict.
Evan
I agree and used the same technics. At least, large enclosures should be done this way. Little enclosures are probably more tolerant.
Old 14th February 2013, 09:04 AM   #26
Cheers!
Wasn't quite sure if 12" or !5" or which model.
Damn nice woofers, I use a couple of RV3143 myself to go with my Tannoy 3148s.
Could I use solid wood like walnut to construct my cabinet?Hide this!Advertise here!
Solid walnut Domus resto hkingman Multi-Way 10 2nd July 2017 12:31 AM
Solid walnut subwoofers project Village Plank Subwoofers 30 20th September 2010 01:11 PM
Fisher 500C Receiver $400 Walnut Cabinet, New Output Tubes Scott Novak Swap Meet 1 16th August 2009 07:16 PM
Walnut for other wood Phergus_25 Swap Meet 0 27th February 2007 03:03 AM
Copyright ©1999-2017 diyAudio
